Page 10 of 10 FirstFirst ... 678910
Results 91 to 97 of 97
    Jun 2011
    #91
    1st month PMS today. BGC doesn't have the service code for the XForce yet and it was tagged as an Xpander. PMS is twice a year afterwards.
    Still no auto parking brake on Park.
    Accidentally ko na disable ang feature ng auto parking brake sa shift to P ng Xpander. Kaya refer sa owners manual...
    Disable: long press dn 4-5 secs ng epb switch.
    Enable: long pull up 4-5 secs ng epb switch.
    Baka ganyan din sa Xforce.
    Aug 2004
    #92
    Quote Originally Posted by bxr monkey View Post
    Thanks for the tip! Went through the manual and ganun nga!
    Start engine then pull EPB up 4 seconds to activate auto park. Push down to deactivate.
    Next yung auto door unlock naman when shifted to P.
    Jul 2013
    #93
    Mitsubishi XForce Hybrid world debut date reportedly locked in | TopGear PH
    reports from Thailand have suggested that the world premiere date for the XForce hybrid has been locked in. Two automotive websites, Autolifethailand and Headlightmag, have reported that the model will make its debut on March 20, 2025.
    Jul 2013
    Jul 2013
    #95
    Look out Yaris Cross hybrid, the Mitsubishi XForce HEV has premiered | TopGear PH
    The Mitsubishi XForce HEV wades into battle with a 1.6-liter Atkinson Cycle engine that’s then mated to 1.1kWh battery and a single electric motor. Total system output is rated at 114hp and 255Nm. Like the standard model, it’s front-wheel drive only, although it shifts with an e-CVT. The company claims a fuel economy figure of 24.4km/L.
    Speaking of Thailand, the XForce HEV will be assembled there instead of Indonesia. The latter will continue building the non-hybrid version.
    Nov 2019
    #96
    Ano kayang e-CVT gamit nila.
    Hopefully similar sa Toyota, which is more reliable daw than the traditional CVT.
    Even much better than the traditional AT.
    Eto daw advantage ng Toyota Hybrid ngayon compare to gasoline engines that uses traditional CVT trans.
    Nov 2019
    #97
    May makapagconfirm naba nito na Aisin daw manufacturer ng e-CVT nito?
Mitsubishi Xforce
