Bg, may kapareho yung atin na pang Land cruiser na fan motor. Also made by Denso.Originally Posted by blue_gambit
Guys, may nagpalit na ba sa inyo ng alternator? Sabi ni Joseph A. buo na daw bilhin ko kesa yung palitan ko lang ng parts. So, anyone replaced their alternator from Bestcolt, Coltline, and SP Intl and how much kuha nyo? Eto lang alam kong shops that sells genuine mitsu parts in Banawe. TIA
Sa Motorix, nung nagtanong ako kung magkano alternator, meron silang Taiwan replacement for 6.5k ata. Tinanong ko kung magkano yun OEM na alternator, 50k daw ang isa
May problema ako ngayon sa JDM ko. As I was driving yesterday night at A. Bonifacio/C3 area going home, bigla nalang akong namatayan ng fog lights tsaka park lights. Headlights ok pa naman. So I thought fuse lang problema. Upon checking today, lahat ng fuse ko buo. Ni-check din namin relays at buo din lahat. Anyone knows nasaan kaya ang possible na problema?
sir freeloader i replaced my alternator to 110 amp at rey electrical marcos hiway second hand cya pero orig brand new ang internals with warranty hindi ko lang matandaan kong 6.5k or 7.5k ang price 1 year ko ng gamit so far wala namang naging problema
Ganyan din problem ko and thrice nakong namamatayan buti na lang sa loob lang ako ng city. I think alternator na problem ko kasi yung amaron battery ko 1 year pa lang and pina-check ko last week ok naman daw. Pa check ko din this week fuel filter and yung gas tank kasi minsan ko na lang ginagamit yung vehicle.
sir freeloader,
I had mine replaced already.. The old one was repaired twice, recon unit..ishin denki at 6.5k..after 6 months, needs changing IC,then after 6 months changed rotor windings. still working good but for peace of mind, i opt to change it with new..
I asked first eldorado in bicutan.. quoted me 50k for bnew oem alternator!
i said, no way! hehe..
then, they suggested to get this nalang.. Bnew unipoint alternator, 90 amps.. Taiwan made yata..
I got mine at 14k..
been using for 1 year palang and running good till now...
later this year, had visited mitparts in banawe and they quoted my 24k for oem bnew mitsubishi electric alternator..i had known mitparts first, rather got that oem..but well see how long this unipoint will do. hopefully tumagal din serbisyo nya.
btw mga sirs, paki enlighten naman ako about this leveling motors and canbus hid kit? d ko magets eh..hehe..
this message was from the pajero headlight manufacturer in china.
DEAR MR. Eugene:
comes with leveling motors
D2S bulbs are 4300K and made by Osram, other bulbs made by Philips
all wiring included, direct plug and play to your car
Canbus HID Kit included
Angel Eye equipped,BLUE COLOR
HID bulb 35W
due to it is expensive,we will completed ballast w/ HID bulb when customer funds come.
I attached some photos
Best Regards
Edgar
ill post pix din sent by the manufacturer.
ganyan dn nangyari sa fuel gauge ko dati sir..
full yung tank pero half lang sa gauge..
i tried replacing with replacement brand na circuit, palpak..umiilaw yung low fuel warning kahit puno..tapos bumigay kaagad..
dahil nga may kamahalan yung oem 3-4k, sinubukan ko buksan yung original na float.
found out na yung needle contact pudpod na..yung coil naman maganda pa..mas nauna napudpod yung needle.
kaya ginawa ko, sinolda ko nalang yung area na napudpod..para bumalik sa dating shape kaya maganda na ulit contact ng needle sa coil..
ayun, 4 years na ngayon ok padin..saka ganda ng scaling nya..every line, gives roughly 20 liters.
kasi pag ifulltank ko, nasa topmost line sya..
then travel ako, say mga 200 plus kms sa tripmeter, pagnagpagas ako, nasa around 20 liters bago mag full..
same with the 2nd line..tatakbo around 400kms, or mga 40 liters..
ill try attaching photo..
this photo was taken during my cavite to iloilo roro trip.
full tank sa carmona petron..reset trip meter..
travelled from cavite to iloilo and refuelled at guimbal, iloilo..
443 kms total distance travelled.. fuel refilled up to full tank 32.8 liters..
13.5 kpl..
