Page 281 of 718 FirstFirst ... 181231271277278279280281282283284285291331381 ... LastLast
Results 5,601 to 5,620 of 14348
    #5601
    question lang mga gurus.
    my electrician was able to revive the oem TPMS monitor. but i have already removed the sensors before. now how will i be able to determine which sensor is for which tire. may easy way to do it ba?
    thanks
    Dec 2009
    #5602
    hi... tanong ko lang po dito sa thread na toh since pareho lang naman po ang engine ng fm sa montero sport 2005 same 4m40 sya... meron po kasi akong montero sport 2005 may leak sya and sa palagay ko sa power steering pump ang may leak... tanong ko lang po kung saan maganda mag pa repair neto? may nabasa akong pede pa naman repair kit lang para mas mura... sana matulungan nyo ko.. from malolos kasi me.. malolos to manila balikan ubos ang power steering fluid... below minimum mark sya... salamat po...
    and may isa pa po akong tanong.. kung saan maganda mag pa lift ng montero/pajero.. alam ko same lang ng pang ilalim ang 2 eh... salamat...
    #5603
    Quote Originally Posted by paolo37 View Post
    Are you sure it is the pump? It may very well be the return or suction hoses too. The return hose is the one that crosses underneath the engine and is half rubber, half metal tubing. The suction hose is easily visible by the engine and is short.
    #5604
    thanks
    tinanggal mo before tapos nakakabit na siya ulit? may label kasi siya sa sensor mismo, FR,FL,RR,RL yung last is spare
    #5605
    Quote Originally Posted by zix888 View Post
    Pinatangal ko nung nagpalit ako ng mags. Check ko mamaya kung may label ba. Kakabit ko sana ulit. Hehe pero palitan ko muna ng battery
    Dec 2009
    #5606
    Quote Originally Posted by K.I.L.L. View Post
    kasi ang napansin ko sa bandang power steering pump ang may leak.. im not sure kung sa pump mismo kasi sa paligid ng pump punong puno ng oil nagkalat sa paligid... im sure na power steering fluid yun kasi yun lang naman ang nababawasan eh... saan kaya maganda mag pa check?
    #5607
    Sir mas maganda, hugasan niyo muna yung pump and surrounding. Para malaman niyo saan exactly yung leak. Pag sa pump, may mga orings lang yan.
    #5608
    alright, but remind ko lang yung system nung sensors, once nawalan ng supply busted yan, so magtap ka muna ng new battery before removing the old one
    #5609
    may i suggest go to MCM 736 BANAWE ST.,near cor. SCT.ALCARAZ, QUEZON CITY
    tel no.: 414-6485 / 708-4672... look for merrick
    #5610
    Quote Originally Posted by junerski View Post
    Junerski - brother, ano yung price range kay MCM?
    #5611
    thanks
    Sir cb, nasira ba whole unit nyan? yung sa akin may part sa display na hindi umiilaw..may replacement ba nito tpms display?
    Dec 2009
    #5612
    pag sa pump ba sir? mura lang magagastos for repair kit? or palit buong pump na? nasa 160k na kasi odometer ko kaya mejo gamit na gamit na...
    saan kaya maganda mag pa lift?
    #5613
    Quote Originally Posted by Pajd View Post
    Nawala buo dati e. Inayos mga wires and fuse.
    Yes sir. Mura lang mga orings. Pag hose, pwede ka naman magpa crimp. Most important thing is magaling yung mechanic sir
    #5614
    Power steering dalhin mo kay richcar sa banawe hanapin mo si lexter...sabihin mo nirefer ni oli yung nagpapagawa ng pajerong pula at crosswind...kakapagawa ko lang last month mura lang inabot...adik sa pajero yun tsaka sa galant, mga clients niya member ng iba ibang pajero at galant gti clubs..your in good hands.
    - - - Updated - - -
    Dec 2009
    #5615
    Quote Originally Posted by oliver1013 View Post
    - - - Updated - - -
    saan banda yung richcar sir?
    #5616
    hindi lang ako sigurado sa price range ng services niya (like yung OH ng steering pump) better give him a call ...member kasi siya ng PPAC so you know your in good hands lalo naka pajero tayo
    #5617
    Ah sige. Il give it a try next time sir. Read a lot about mcm nga sa ppac.
    Aug 2009
    #5618
    Good pm, sir need help. ung sa pajero fieldmaster sensor. what does "noS" stand for? tinangal namin ung gulong tapos. nakakabit lang ung sensor. ok naman
    pls help
    Dec 2009
    #5619
    mga sir.. nag pa canvas na ko ng power steering pump nasa 7-8k pala sya surplus.. hindi na kaya ng repair kit kasi nag crack na yung housing ng pump.. saan kaya maganda maghanap ng surplus na mura mura?
    #5620
    Have a happy pajero Christmas folks!
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
