Page 248 of 718 FirstFirst ... 148198238244245246247248249250251252258298348 ... LastLast
Results 4,941 to 4,960 of 14348
    #4941
    Quote Originally Posted by zix888 View Post
    sa harap madali lang, pihit lang ng screw sa torsion bar, sa likod pwede cushion sa coil spring. kung buo naman shocks, no need palitan
    Thanks sir! parang yung sa lite ace at revo pala namin dati, pinipihit lang. Ok pa naman yung shocks, and mga 9k pala isa nun.whew! Sir ano po yung cushion sa coil spring na sinasabi niyo po?
    #4942
    Quote Originally Posted by sleeepy View Post
    i think zix is referring to the o-sulee spring cushion...
    O-sulee Spring Cushion - The World's only modular Spring Cushion | SpringCushion.com.ph
    Apr 2012
    #4943
    Quote Originally Posted by junerski View Post
    Puede ba to sa Pajero Exceed ? Mga how much po kaya to and where kaya puede makabili at painstall. Thank you !
    Jul 2005
    #4944
    I think due for injector cleaning or calibration na ang Pajero ko. Between Denso and Central Diesel saan ba mas mura and ok ang trabaho? How long ba usually ang process? Pwede ba iwan while being fixed or dapat tutukan?
    Malapit lang sana dito sa amin ang Berrima mahal yata.
    #4945
    Ang experience ko lang ay ang Central Diesel. Dyang ginawa yung FM ko. They are pro at yung trabaho ay garantisado. Alam nila sakit mg FM so madali lang sa kanila yan. Kailangan iwan mo sasakyan mo ng 2 days at least.
    #4946
    Quote Originally Posted by PapaPaj View Post
    pwede basta may coil spring ang kotse... sa likod lang sa atin mga pajero since wala tayo coils sa harap... visit their website ^^... may list dun ng distributors para kung saan malapit sa inyo... warning though that blade stores do not install these... kaya i suggest dun sa mga auto accessories shop like roadstar or yung mga nasa banawe
    Aug 2009
    #4947
    mga sir, repairable po ba ang "down-up" screw adjustment ng headlights natin? Patulong naman po and TIA po...
    Apr 2012
    #4948
    Guys ask ko lang psi nyo for front and rear tires. Ano b normal psi from the mits manual ? Thank you
    28psi front & back if wala karga. 28psi (F) & 30psi (R) naman yung usual if palagi more than 2 passengers ka afaik.
    #4950
    Sa akin 34 all around. Sa manual 26 and 28 yata. Basta below 30
    #4951
    28-30psi. Pero ang pressure ng gulong ko ngayon is nasa 34psi. Sabi nung iba, di naman daw dapat sundin yun psi na nasa manual kasi sobra daw baba. Masisira lang daw yun gulong lalo na pagka may karga na yun sasakyan mo
    Apr 2012
    #4952
    All 34 Sir Testa ? Thank you sa feedback..
    Apr 2012
    #4953
    Thanks Sir CB
    Apr 2012
    #4954
    Thanks Sir Ry. Usually 30 ako all tires but subukan ko now yung 34 all tires. feeling ko kasi parang malambot gulong ko pag 30psi pero soft sya naman pag tumaktakbo kahit lubak.
    Oo, parang malambot nga, 32 front 34 rear naman ako.
    #4956
    yung sticker sa may center pillar beside driver seat , 26 and 29 (F&R) ang naka- indicate(265 70 16 tires), pero ako 28 lang lahat
    #4957
    Iba iba yung pressure na gamit natin. I'm using 30 psi sa apat na gulong. Tingin ko sa side ng gulong ay tama lang ang tindig niya sa 30 psi siguro depende sa gulong na gamit.
    #4958
    pwede! sakin naman i based it sa upod ng tires plus comfort. sa 30 same lang sa kain ng tires, but noticeable comfy ng 28, considering konti lang difference in tire pressure. pagdating ko din kasi ng manila. 30 na rin reading niya sa tpms, kaya stick lang ako sa 28
    #4959
    karga ko po 32psi.. medyo mataas kesa normal para tipid sa diesel
    totoo po ba yun? makakatipid pag mataas hangin?
    may sideeffects po? maliban sa harder ride?
    madali po kaya magcrack tire?
    nabasa ko mas mauuna mapupudpud gitna ng tires pag mataas hangin but sa case ng akin.. wala naman po ako nakikitang sign na ganun
    nabasa ko kasi... pag kulang sa hangin.. malaki daw itatakaw ng sasakyan
    anyone here use nitrogen? ako plain air lang.. but madami nagaalok ng nitrogen.. but iniisip ko kung may use po ba talaga? since... 71 or 79 % yata ng air natin diba nitrogen.. hehe
    may friend po ako 45psi ang hangin.. but not on pajero.. he is on a tuscon... iniisip ko too much.. pero mga elf namin 70psi to 80psi depende sa karga e... kaya hindi ko alam kung sobra nga ba 45.. hehe
    #4960
    Quote Originally Posted by AC View Post
    Naka nitrogen yun Pajero ko. Libre kasi pakarga ng nitrogen that time doon sa GTD once na sa kanila ka bumili ng gulong. Simula nung nagpalit ako ng gulong last March, di ko pa pinapakargahan ulit ng hangin yun mga gulong ko. Kung ano naman difference ng nitrogen sa ordinary air, ewan ko pero sa akin, di ko masyado pansin. Magkano na ba magpakarga ng nitrogen sa ngayon? AFAIK, noon eh abot pa ng 100 ang pakarga dito.
    May epekto din talaga sa FC ang tire pressure ng gulong. Opkors, pag sobrang baba ng pressure ng gulong, tendency nito eh medyo babagal takbo mo at lalakas ang FC. Sa pagkakaalam ko, dapat within standard ang pressure ng gulong to maintain standard FC.
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
