Page 211 of 718 FirstFirst ... 111161201207208209210211212213214215221261311 ... LastLast
Results 4,201 to 4,220 of 14348
    #4201
    Quote Originally Posted by Paj699 View Post
    Sir crazy boy ask ko Lang yung nozzle ba ng fm natin pwede ipa-adjust or palitin talaga? Kasi yung isang friend ko yung nozzle daw niya eh d muna niya punapalitan pinaadjust Lang daw niya sa may c5, kasi medyo malakas n me s diesel
    baka hindi nozzle? baka retarded yung injection pump niya?
    disposable ang nozzle tips e
    Mar 2012
    #4202
    May nut yan sa taas, yun ang tatanggalin tapos mabubunot na yan. Kayang-kaya ng mekaniko yan with proper tools, hindi naman maseln ang pagtanggal.
    Quote Originally Posted by zix888 View Post
    tapos pagbabalik nung sensor, check mo if yung position nung paglalagyan ng sensor, sa center kasi mayroon maliit na rod half moon siya, yung sensor mo check mo yung may opening na half moon din. nangyari kasi sakin yan, basta lang sinalpak nung mekaniko, napansin ko na lang iba ride nung shock na yun, chineck ko, ayun ako na lang nag ayos
    Sir Ry, Zix.. thanks sa reply. Just to confirm....
    - Pull the sensor connector plug muna.
    - Then remove the upper nut and the sensor will be loosen also?
    - Remove the bushing and lower nut.
    - Then after ko mareplace all the bushings, reinstall the sensors basta aligned yung half moon ng rod and sensor.
    - Reconnect the plugs
    - Then double check it they are functioning right.
    Pwede bang linisin yung mga sensors or leave it as is lang?
    Thanks again!
    Mar 2012
    #4203
    Mukha nga lol kaya nagulat me sa sinabi niya hehehe, medyo madugo Lang ang nozzle 7k lahat magagastos ko para Lang tumipid me s diesel 5km/L yung s akin then long drive going to batangas 12km/l, sir crazy boy Wala ba eb dito para meet ko naman ung people dito s tsikot
    Quote Originally Posted by Zipspeed View Post
    Thanks again!
    You don't need to pull the sensor IMO.
    Kahit hindi mo na linisin yan basta hindi rin marumihan. Ibalot mo ng plastic while removing old shocks and putting the new OEM shocks if I'm not mistaken. Pero kung hindi OEM ang ipapalit mo na shocks, hindi ma-rere-install ang sensors ha, Balutin mo na lang at itabi dyan sa chassis.
    #4205
    Nung nag inquire ako dati sa palit ng Nozzle meron daw inaadjust and if my memory ay correct washer daw ang ginagamit pang adjust. Aside from the calibration ng Pump.... You can call Bosch to be sure or PM dieseldude...
    Sali ka sir dito http://tsikot.com/forums/car-clubs-f...07/index2.html
    Mar 2012
    #4207
    Will do. Actually bushing lang papalitan and hopefully mawala yung metal sound sa likod. Hindi ko pa rin kaya magpalit ng OEM shocks, mahal kasi e. Baka nga gamitan ko na lang muna ng O-sulee. Thanks again!
    Nov 2004
    #4208
    Mga boss need your input on best location to put amplifiers of audio setup sa FM. Cant mount them under the front seats theres no space. I have two amps to install, one 2-channel for the separates and raw drivers - one mono-amp for my sub. Mounting the amps on the sub is not an option, I need to detach and dismount the sub(box) when need space. I already asked an audio shop but the owner told me the only option he did before was mounting it on the sub box impossible to remove the sub when needed. Salamat mga ser.
    Mar 2012
    #4209
    Sir blue gambit may number kayo ng Bosch para matawagan ko, kasi yung friend ko dun daw s kakilala niya eh pina-adjust Lang daw pero parang nakakatakot kaya plan ko mag palit ng new nozzle para tumipid sa diesel
    #4210
    Quote Originally Posted by halimaw View Post
    Kung yung 3rd seat mo sa side facing, you can install the 2 amps under the 2 jump seat. Yung sub mo ay sa center ng 3rd seat. Pwede itong di tangal.
    Yung sa akin ay front facing yung 3rd seat ko kaya hindi pwede sa ilalim ng upuan. Naka latag sa floor at yung set up ko ay using an active subwoofer and amp. Pag gamit yung 3rd seat, natatakpan ng seat yung amp at yung active subwoofer.
    Apr 2012
    #4211
    Guys, fuel consumption ko now is 5.4 based sa last full tank ko. Last month pumapalo pa ako ng 8/l. Lagi ako todo sa aircon kasi mainit 18 high fan. Pano ko malalaman if bumaba fc ko due to aircon o may problem na sa nozzle tip at injection pump? San pala maganda magpacheck ng injection pump and nozzle tip if due na - ung okay at d mataga? 193k na odo ko na pala not sure if time na magpacheck Thanks sa mga magaadvice.
    Mar 2012
    #4212
    Sir papapaj pareho tayo ng problem last option ko pagawa ko kay joseph kaso Wala p budget
    #4213
    eto http://www.malabon-diesel.com/
    On Subs subject
    Yan din problema ko, where to put those amps currently naka mount din sa sub box at di-na drive pa nya yung 6x9 sa likod .
    Was thinking kung sa Ceiling tulad sa CR-V na sound cruiser edition...
    *paj699 & papapaj... have you checked your air filters? baka mamaya cloggged na ?
    #4214
    mga ok na calibration/injection pump centers
    Malabon Diesel Injection Service, Inc.
    Diesel King Injection Pump Calibration Services
    Lot1 Block16 Phase3 E1 Dagat-Dagatan Ave.,
    Caloocan City 1400 Philippines
    Telefax 02.287.0485. 287.5882 and 287.4954
    Smart 0920.903.2524 Sun 0922.890.3252
    Central Diesel
    CENTRAL DIESEL BLDG
    1176 Quezon Avenue,
    corner Scout Magbanua St.
    Quezon City, Metro Manila
    Philippines 1103
    +(632) 4113711-13
    +(632) 4112927
    +(632) 3712893
    Malabon Diesel - Pampanga
    Central Luzon Zexel Service Center, Inc.
    Lot4 Blk1 Mc Arthur Highway, Bgy Del Pilar,
    San Fernando, Pampanga, Philippines
    sun 0922.801.7516 smart 0919.327.7435
    digitel 045.861.0341 pldt 045.961.5040
    Berrima Diesel
    219 J. P Rizal St. Brgy. Mabini - J. Rizal,
    1150 Mandaluyong City, Philippines
    Phone # : 02 533-1415
    Apr 2012
    #4215
    Quote Originally Posted by junerski View Post
    Central Diesel
    CENTRAL DIESEL BLDG
    1176 Quezon Avenue,
    Philippines 1103
    +(632) 4113711-13
    +(632) 4112927
    +(632) 3712893
    Berrima Diesel
    Thanks Sir Junerski.
    Nov 2003
    #4216
    Central Diesel
    CENTRAL DIESEL BLDG
    1176 Quezon Avenue,
    Philippines 1103
    +(632) 4113711-13
    +(632) 4112927
    +(632) 3712893
    Berrima Diesel
    Sa price sino pinaka reasonable?
    Balak ko dayuhin Malabon Diesel, pero kung same lang naman sa Central, o Berrima, di nako lalayo pa.
    #4217
    Quote Originally Posted by nic View Post
    Call them up, sabihin naman nila syo how much ang rate nila. Pero pede ka naman tumawad yata pag actual na. In your shoes kung san malapit. Berima turbo specialist yata sila...
    Mar 2012
    #4218
    Ganda n tumakbo ni bigboy tawag ko s pajero ko new change oil, air cleaner, oil filter and fuel filter c/o Joseph A.
    Apr 2012
    #4219
    Paj, OEM pinalit na air filter sayo ? magkano damage lahat ng pagpapagawa mo kay Master Joseph ?
    Apr 2012
    #4220
    I think due na air filter ko, maitim na loob. anu ba magandang air filter ? tuwing kelan ba palitan ? okay ba na OEM pa din ipalit ko ?
    TIA sa mga mag aadvice.
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
