Results 10,171 to 10,180 of 14348
April 25th, 2014 10:08 AM #10171
nag pa plano din ako bili pajero. anu ba ang pag kakaiba ng exceed sa field master? anu ba ang mas maporma at maayos ang performance sa dalawa?
April 25th, 2014 12:17 PM #10172
Exceed is Japan surplus, in short mga Pajero na galing Japan. Ang Fieldmaster eh local Pajero. Sa mga Exceed pala, meron dyan na kapareho din ng body ng local Fieldmaster pero mas madami ang Gen 2 body.. May 3 types yun Exceed, 2 diesel engine at 1 gas engine. Yun diesel, 4D56 (walang hood scoop), at 4M40 (with hood scoop). Feature wise, mas madaming features ang Japan Pajero kesa sa local counterpart, like climate control, sunroof. Tsaka lahat ng Pajero na galing Japan ay 4WD, unlike sa local Fieldmaster na yun mga models 98 up to 99 lang ang 4WD, later models ay 2WD lang.
April 26th, 2014 02:12 PM #10173
Found the cause of the squeaking sound in my engine bay. Cause was broken ac tension bearing. Damage: 108 for bearing. 200 for labor.
Posted via Tsikot Mobile App
- Jun 2004
- 476
April 26th, 2014 04:09 PM #10174
- Jun 2004
- 476
April 26th, 2014 04:11 PM #10175
April 27th, 2014 06:53 AM #10176
Update doon sa garalgal na naririnig ko.
Sinubukan ng tatay ko baklasin yun alternator dahil nakita niya na tabingi yun alignment ng alternator pulley doon sa crankshaft pulley, then pina-start. Ayun, walang garalgal. Wala din siyang nakitang obstruction doon sa impeller ng turbo at maayos na umiikot yun impeller at walang din unusual sound. So ginawa nalang namin eh kinabit namin yun lumang alternator ko at ayun, problem solved. Papaggawa ko nalang yun isang alternator ko at may gewang at may sabit na rin yun ikot niya. At the same time, papapalitan ko ng pulley na mas manipis.
April 27th, 2014 07:24 AM #10177
April 27th, 2014 08:54 AM #10178
April 27th, 2014 09:27 AM #10179
Does the local 2008 fm have chain type timimg belt?
April 27th, 2014 09:32 AM #10180
Timing chain na po lahat ng 4m40.
Sent from my Nexus 7 using Tapatalk 2
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
