Page 25 of 31 FirstFirst ... 15212223242526272829 ... LastLast
Results 481 to 500 of 616
    Oct 2016
    #481
    Sa akin din po for MS 2011 GLS-V. rcrojojr*gmail.com
    Thanks!
    Sep 2014
    #482
    Hello po mga Sirs/ka-Monty!!!
    Pwede din po ako makahingi ng security alarm manual (2011 MS glx). Email add ko po: KooL_JC*yahoo.com
    Sinubukan ko na mag-google wala ako mahanap na guide, nag backread na rin po ako, tinry ko mga suggestions, ayaw talaga.
    Salamat po ng marami! (:
    May 2012
    #483
    Quote Originally Posted by Jerico Mamaril View Post
    Encountering the same issue below:
    Help! 2014 MS GLX owner here. Car would lock using the keyless entry but would not unlock. Tried both remotes but same result. Noticed that the park lights does not blink when locking the car. Also, the alarm would make the arming sound every 30 seconds to 50 seconds. Not sure how to reset it. Tried pressing and holding the alarm button under the dash and turning the ignition to on. Nothing happened. Grateful for your responses. The only time the arming sound would stop is when I leave a door or trunk open. Thanks for your responses.
    May i also request for a manual copy? Or how you able to resolve the issue for those who encounter also the same issue.
    email: jericom77*yahoo.com
    Thanks.
    Just now, im having these problem in my alarm. What was the solution sir? How did you get to fix it?
    Sent from my ASUS_T00I using Tsikot Forums mobile app
    Mar 2013
    #484
    Hi, I need help on my Strada GLS 4x4 2007 central lock/alarm, I know the thread is about Montero alarm, just hoping that maybe anyone knows and can help. My keyless remote doesn't engage the central lock/unlock. It engages the car alarm but not the keyless entry. I have to manually use the key and open or lock the door. It was okay previously but when I had car serviced for maintenance to a local mechanic, when I got it back the problem occured. I asked if they know how to change it back but they don't know. They might have deactivated it without knowing. Hope someone can help. I appreciate it also if the alarm manual can be sent to me, my email is xcx953*gmail.com Thanks in advance!
    Jun 2016
    #485
    Mga sir nagaalarm mag isa yung monty ko 2012 alam nyo b ano problema neto? Tnx
    #486
    Kapag nakapark ka lang and patay makina, either nakasaksak ung susi or wala, if u lock the driver side door from inside, nag-aalarm din ba sa inyo?
    Gusto ko din sana kase nakalock from inside kahit nakapark ako for safety, kaso nagaalarm nga...
    Malamang may nakafigure out na nito so pa-advise naman [emoji4]
    #487
    Quote Originally Posted by typhoon View Post
    My experience bro.,- if you lock the door from the inside (driver's side),- it would activate the alarm or security system, but will not trigger an alarm, unless you open a door.
    While inside the vehicle,- did you try locking the doors using your remote? It should just do the above right?
    _/_/_/
    31.8K _/_/_/_/_/_/_/_/_/_/
    #488
    Havent tried locking from inside using the remote. I can try this.
    Locking manually kase from inside immediately triggered the alarm kaya nagtataka ako kung ganito din ba sa iba.
    Jun 2015
    #489
    Most likely whether you lock from inside or outside, even with the remote, maa-activate pa rin ang alarm.
    What you can do is lock from inside and when you're ready to get out, unlock with the remote so it won't trigger the alarm. You may have to have to open a window and hold the remote out.
    If you're going to be moving around in the car, you should lock the door with the remote by pressing the lock button twice to get 5 chirps para disabled ang shock sensor.
    You could also just leave you car on ACC mode so you can lock without activating the alarm. It probably won't drain your battery that much.
    Last option is valet mode.
    Mukhang pareho lang pala ang alarm system ng Mirage at Montero. I thought the Montero would have a more sophisticated alarm system.
    Tapatalked
    Jan 2011
    #490
    Hi Sirs,
    Anyone of you got a copy of the manual? Pa-send po sana ako: marunillo*gmail.com
    TIA!
    Sent from my Nexus 6P using Tsikot Forums mobile app
    Jul 2004
    #491
    Quote Originally Posted by uramaru View Post
    Hi Sirs,
    TIA!
    EMail sent
    Jan 2011
    #492
    EMail sent
    Thank you sir!!
    Mar 2017
    #493
    EMail sent
    bossing baka pwede din pasend sa email ko ung manual...hassle eh...2017 montero sport gls model.... valet mode datingan... ayaw mawala blue led light..ced_tiny*yahoo.com ... Thank you!
    Jul 2004
    #494
    Quote Originally Posted by Bronzy_2017 View Post
    Alarm manual I have is for a 2011 MS. Not sure if this is the same for the 2017 MS
    Nevertheless, I emailed you the manual.
    Hope it helps
    Apr 2017
    #495
    Hope it helps
    Good am sir, baka pwede mo rin sakin. Pareho din kasi problem ng 2017 ko ayaw mawala yung blue led light. Salamat ng marami!
    Hope it helps
    markcastrence*gmail.com
    Mar 2005
    #496
    Good day sir, makisuyo na din ng manual ng alarm. Dbcruz*yahoo.com thanks
    Mar 2005
    #497
    Quote Originally Posted by beeper0358 View Post
    Got the email sir 111prez
    Apreciate the help
    Jul 2004
    #498
    Quote Originally Posted by MARKEEH View Post
    Email sent
    Sana makatulong
    Apreciate the help
    No problem
    Nov 2007
    #499
    Boss,
    Pa email na rin sa period.point*yahoo.com
    Salamat!
    May 2017
    #500
    Bro ok na ba alarm mo? Having the same problem with 2016 gls premium. blue led light always stays on. Pasend naman ng manual for the alarm.
    kevinmerced1985*gmail.com
    TIA
Mitsubishi Montero sport alarm
