Results 261 to 270 of 615
- Mar 2014
- 291
- Jan 2014
- 15
April 11th, 2014 11:54 PM #262i have strada glx v 2014
ask ko lang po if pano mag set ng program
ginagawa ko po kasi ganito:
system option #16 - disarm chirp - button 1 (remote button - lock) [normal / with sound] - button 2 (remote button - unlock) [disable sound]
put ignition key to 'ON'
press red button 5 times; alarm will chirp once
press red button on 16 times
press remote button - unlock; 3 chirps heard (expected ko na 2 times sya mag chirp to confirm na unlock button yung priness ko)
put ignition key off
when i tried to unlock, may sound pa rin. my objective is to remove the chirp when unlocking
may mali po ba sa steps na ginawa ko? may missing po ba sa steps?
- Nov 2013
- 17
April 16th, 2014 12:49 AM #263May tanong lang ako sa alarm ng 2013 MS GLS-V. Naka-connect pala yung alarm sa lock/unlock button sa driver's side door kaya kapag nagalaw mo yung button kahit bukas yung sasakyan, nag-aalarm minsan. Paano i-disable yung function na ito? I mean gusto ko lang yung alarm na hindi konektado sa lock/unlock switch sa driver's door.
If not, mayroon ba sa inyong may hawak ng alarm manual ng 2013 MS??? Pa-send din naman sa mvtbel*yahoo.com
Thanks.
- Apr 2014
- 1
April 16th, 2014 06:36 AM #264Sir please send alarm manual for Monty 2014 glx to jigrng*gmail.com thanks in advance and more power!
April 16th, 2014 11:52 AM #265
Sirs,
Do you still have the alarm manual? Ask lang po ako sana ng copy nito (mightypaps07*gmail.com), I would like to adjust yung sensitivity nung alarm para hindi lagi naka vallet mode. ( Mag ka issue po ba ako if lagi siyang naka vallet? ) thanks!
Would you know exactly where the adjustment for the alarm sensitivity is located sa monty?
Best of thanks!
- May 2008
- 6
April 25th, 2014 02:37 PM #266Hello po, pa email din po ng Soft Copy ng Alarm Manual. kentrusse1*yahoo.com
Salamat po.
- Apr 2006
- 23
April 25th, 2014 04:56 PM #267Sir prince,pls also send alarm manual for MS GLX 2014 * anton_cervo*yahoo.com.TIA!
- Mar 2014
- 7
April 25th, 2014 06:23 PM #268Anybody pls email me manual of alarm e_stop_888*yahoo.com. Thanks in advance
April 30th, 2014 01:43 PM #270
Would also like a copy of the Montero alarm manual. Kindly send it to kuplet*hotmail.com
Thanks in advance
high idle RPM at engine start
