Results 671 to 680 of 739
- Jun 2012
- 4,447
October 12th, 2014 07:10 PM #672
tried to back read but couldn't find the answer.
anyway, would like to know the required spec of gear oil and transmission oil for the L300. and ilan liters kailangan? thanks in advance!
- Nov 2008
- 641
October 22nd, 2014 09:59 AM #674The Immortal L300! Great efforts by Centro here. Hope the A/C system's sufficient and wont encounter future overheating problems. Also, the old 4D56 might be too underpowered considering it'll be hauling 17 pax in it (plus of course the added weight of the new body). Anyway, for its price, it might be a good alternative for those shuttle services.
- Nov 2012
- 3
November 29th, 2014 02:45 PM #675Good day. I have some queries hoping other members can provide some infos.
1. anyone knows the standard speaker size for the front doors of our L300 versa van? i noticed ang mga FB has their front speakers mounted sa doors, malamang may abang na butas na. Our versa van OEM speakers are currently located at the back of the driver i think its 4" size and the other one sa sides of the middle row seats, before sa tambol ng rear tires which are 6" or 6.5" i think. if listening from the driver and front passenger, mahina ang marinig mo pero if you're seated sa likuran, malakas naman. i wish to have equal hearing levels for both front passengers and rear passengers
2. what is the default radiator cap pressure? ours is currently using 0.9 kg/cm but temperature still reaches 3/4 during traffic w/ a/c on, with aux fan already installed. is it possible to use a higher pressure cap like 1.1 or 1.3? has anyone already tried it? would like to know also the results.
thanks.
- Apr 2009
- 429
January 2nd, 2015 04:20 PM #676
for #2 Q: the OEM rad rating is 0.9kg/cm (88kPa). yes you can use higher pressure rad cap but you have to make sure your rad hoses and other hoses for the cooling system are still up to the task (ie, not oxidized). You might also want to check if your thermostat is still working properly or your radiator's "internals" are partially blocked (with sediments) thus the poor heat transfer.....
January 2nd, 2015 06:32 PM #677
there must be something wrong in your cooling system. check your radiator, baka barado., change coolant and check the temp sender. yup, baka barado na rin ang thermostat. panahon na para palitan. wag mong tanggalin ang thermostat gaya ng ginagawa ng karamihan. it will do more harm than good.
January 16th, 2015 10:18 PM #678
hello L3 users, baka meron kayo jan litrato showing the differential and the left side of the chassis malapit pa rin sa differential. parang may tinanggal na piyesa kasi sa L3 ng pinsan ko with regards to its brake system. parang tinanggal na yung proportioning valve kaya parating matigas ang pedal at naglolock ang gulong sa likod lalu na kung walang pasahero.
salamats sa kung sino man ang makakapagbigay ng info tungkol dito.
January 16th, 2015 10:19 PM #679
Tsikot Member Rank 1
- Jul 2009
- 4,090
I use imgur.com. Upload the picture there, then get share links, choose bbcode and paste here.
Mineral , semi synthetic or fully synthetic?
