Hi! We have a 2003 Mitsubishi Adventure, when I tried to open the locks via the remote, it doesn't open so I had to use it manually. I thought it was the battery of the remote but we changed its batteries recently. It was on engine lock so it will not engine start since I used the key manually instead of the remote, but when I switched the ignition key, not even the lights on the oil, temp, etc were lighting up. We already changed the battery before and I used it a week before and was working fine.
We suspect it was electrical wiring failure but the mechanic is still not available to check. Are there any possible causes that this had happened besides wiring?
Also how much will it cost if we fix the wiring if it is the case?
Thank you
