Results 1,821 to 1,830 of 2048
- Feb 2019
- 1
February 22nd, 2019 03:07 AM #1821Your problem is Exactly the same as mine, GLS V 2012 - how did you fixed yours? tried changing inhibitor switch and change atf but still the same., Im only experiencing this when Im driving going up and going down to/from baguio, and when Im driving aggressively like high revs but driving in normal the car is ok.
- Mar 2019
- 2
March 10th, 2019 07:52 PM #1822Hello mga Sers!
I’m just a Newbie sir. Mine is MS 2014 GTV & I observed when I start the engine & I switch ON the aircon, the compressor will run ON & OFF & simultaneously the AUXILIARY FAN (the small Fan in front of the radiator) is also running ON & OFF. But after sometime, I observed the AUXILIARY FAN is not running anymore while the compressor is continuously running ON & OFF.
Is it normal that Auxiliary Fan will not RUN after a longer time of driving?
Lately po kc naka experience ako ng HIGH TEMP reading sa dashboard. Anybody experience the same scenario? Need help please. Thanks!
- Mar 2019
- 2
March 10th, 2019 09:12 PM #1823Ser:
Under waraanty paba yan?....papalitan mo agad ang LCD monitor unit mo.
Sakin kc ser naexperience ko nman yung SOUNDS niya biglang lumalakas, once hininaan mo volume lalo nalakas ang sounds, kakahiya. What i did i press the MUTE knob. minsan nman ok ang sounds. Ask ko Winterpine, sabi nila problem na LCD monitor ko at pinalitan nila ng bago. Now happy ako sa sounds.
Kaya suggest ko, go to winterpine for replacement.
- Apr 2017
- 3
March 13th, 2019 12:13 AM #1824Just sharing.
My monty is turning two years this March 21 and i am nearing 30k mileage. When i had my PMS this morning both rear shock absorbers were replaced because they have leaks already. I am a careful driver and I do not overload the car. I just thought its too early for the stock shock absorbers to retire.
- 54,293
March 13th, 2019 12:16 AM #1825
March 13th, 2019 12:52 AM #1826
- Apr 2010
- 201
March 13th, 2019 11:09 AM #1827Is it normal sa montero na kapag kakastart lang talaga sa morning then pag apak sa gas e high rev sya then di masyado umaabante? pero if napainit for atleast 20 seconds siguro normal na?
- Aug 2017
- 870
March 13th, 2019 11:13 AM #1828
- Apr 2010
- 201
March 13th, 2019 11:18 AM #1829
- Aug 2017
- 870
March 13th, 2019 11:22 AM #1830
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
