Results 1,941 to 1,950 of 2039
- May 2016
- 546
March 9th, 2020 11:04 PM #1941Cabin filter every 20k palit or pag mahina na lamig ng AC.
Fully synthetic good for 10k or 1 year, depending on driving conditions. Pero marami na fully-synthetic na mura ngayon, pwede na rin mag 6 months interval lang.
What's the mileage of your unit sir? Crucial pacheck mo timing belt, palit kasi nyan 80k sa 4d56. Wag hayaan kahit mukang nasa condition pa, pag naputol kasi instant overhaul yari.
- May 2017
- 2,099
March 9th, 2020 11:19 PM #1942
- May 2016
- 546
March 9th, 2020 11:39 PM #1943Hyundai Xteer, Zic X7. You can also try Delo MGX, semi-synthetic nga lang pero goods din. Around 2k 7 liters for the aforementioned. Di aabot ng 3k for basic oil change kasama na oil filter and labor.
Kaya di ko gets yung iba bakit tinitipid magpa change oil, babalikan ka rin sa gastos in the long term pag kulang maintenance.
- May 2017
- 2,099
- May 2016
- 546
March 10th, 2020 12:07 AM #1945
- Aug 2008
- 26
March 10th, 2020 09:52 AM #1946
I got the unit nasa 52k.tapos nag change oil ako used petron rev x ung fully synthetic at 54k. Pati ATF and gear oil.palit narin break fluid ulit.sabi naman ng mechaniko oks pa yung timing belt.pero malamang mga sa 70k magpalit nako depende parin. OIL filter ko gamit donaldson. Pwede kaya sa 10k ko na palitan ung oil since fully synthetic naman?and usually every weekend ko lang gamit car ko from makati to marilao bulacan lang ang byahe.siguro mga 60 km lang per week balikan pag gamit ko sya.right now mag 55k na mileage ko.got the unit last december 2019.Di bale ang gagawin ko pa is palitan brakes sa likod.Tapos coolant 30-70 mix pwede na yun noh? Then last na siguro yung power steering fluid. BTW nakapagpa cleaning narin ako ng egr at intake.
- May 2016
- 546
March 10th, 2020 10:34 AM #1947Depende rin, kung over 1 year bago mag 10k, change oil na lang yearly. Nag degrade kasi oil over time. Di ako familiar sa Petron Revx, pero sounds like rebranded oil. If the specs are within the recommended sa manual, I don't see any problem.
Sa coolant, just get pre-mixed para fill and forget.
- Aug 2008
- 26
March 10th, 2020 11:07 AM #1948
Yup planning to change the oil yearly.
Sa coolant naman may makuhan din ako mga 1k plus dia queen din ung super coolant nila ata un.planning na palitan lahat pati ung nasa engine block para talaga ma monitor ko kasi wala yung booklet kaya dibale ng magastos at least start sa akin lahat.parang back to zero. Thank you sir sa mga advise. By the way may nakapag install na ba rito ng additional aux fan?
- May 2016
- 546
March 10th, 2020 01:12 PM #1949
March 10th, 2020 01:25 PM #1950
While ford does not specify time-based intervals for The AT ZF specifies a 8 year interval for the...
Ford Everest 2015
