Results 1 to 10 of 23
Threaded View
    Hi. Can you suggest an alternative Automatic Transmission Fluid (ATF) brand other than the OEM Mitsubishi ATF that is the same spec (Mitsubishi ATF SP III) and is locally available in the Philippine market? The current ATFs being sold locally the last time I checked (i.e Petron, Caltex, Shell, Castrol, etc...) only meet the Dexron III spec and not the Mitsubishi ATF SP III spec.
    Thanks.
Can you suggest alternatives to the OEM Mitsubishi ATP SP III?
