Results 1 to 9 of 9
July 26th, 2012 02:28 PM #1
guys ask ko lang. balak ko kasi bumili ng 2nd hand step board for my 2011 adventure. the problem is nung may nakita ako ang sabi drill daw or welding para ma install yung step board. since may warranty pa yung advie ko. mawawa ba warranty pag ni-drill or welding yung step board? thanks!
July 26th, 2012 07:29 PM #2
if sooner (hwag naman sana) na may nakita o nireklamo kang defect or sira that was caused or partially caused by the drilling or welding process, hindi honored yung warranty mo.
but since tingin ko naman, sa body or sa chassis i drill yun, malamang ok lang yun.
di ko sure ha.... check natin ibang experts dito.
August 1st, 2012 10:41 AM #3
[QUOTE=guys ask ko lang. balak ko kasi bumili ng 2nd hand step board for my 2011 adventure. the problem is nung may nakita ako ang sabi drill daw or welding para ma install yung step board. since may warranty pa yung advie ko. mawawa ba warranty pag ni-drill or welding yung step board? thanks! [/QUOTE]
welding or drill???WAG bos.....welding weakens the steel di ba...bat di pa yung bolted or yung may bracket ang kunin mo.anytime mo gusto tanggalin,madali lang...also if bibili ka ng 2nd hand na welded, ndi na matibay ang plates or bracket nun....even mga auto shops ndi nagrerecommend ng welded type...they are only selling those type dahil yun ang options ng buyers na naghahanap ng mura...pero kahit sila, they prefer the bolted one.Last edited by amir1223; August 1st, 2012 at 10:45 AM.
August 1st, 2012 09:27 PM #4
oh no.. nakabit na yung step board ko. wala kasing bracket yung step board kaya gumawa sila ng bracket. winelding nila dun sa may chasis. inaalala ko nga baka kalawangin yung bracket kaya balak ko papinturahan + undercoat nadin. inaalala ko lang kung void na yung warranty
August 6th, 2012 02:10 PM #5
may recommended brand/type ng step board po ba kayo para sa adventure? Saan po ok bumili at magpakabit at magkano po kaya?
- Jul 2012
- 81
August 6th, 2012 02:16 PM #6
- Jan 2007
- 173
August 10th, 2012 03:03 AM #7yung sakin step tube... ampanget kase nung mga step board sa banawe sobrang ninipis parang pag nasagi punit na. Plus step tube can be repaired kase stainless lang sya pde i bend or pukpok. It is very usefull kse dun ako umaapak pababa. instead na gamitin ko yung running board. Di maganda yung welding source yan ng kalawang, Yung sakin nag fabricate ng harness puro bolt on lang walang welding... Katamaran lang kase ng nagkakabit pag welding
August 11th, 2012 02:56 PM #8
Sir Japeeps, pwede po ba pa-post ng picture nung step tube nyo? Tsaka magkano at saan nyo po pinagawa? TIA!
For modern cars, the EPS seems to be more ubiquitous as the traditional engine-driven PSF...
A/c
