Results 1 to 5 of 5
    2003 2.5 advie 4d56AAN0500 is my ride, and ang tigas tapakan ng clutch. Can somebody help me with this problem.TIA
    Apr 2005
    Quote Originally Posted by arnielbenz View Post
    If I where you I will send the unit to Mitsu Casa for check up.
    Quote Originally Posted by trackers888 View Post
    - agree!
    baka pressure plate yan. how many KM ang odometer?
    May 2007
    If hydraulic clutch, no adjustment.
    Is it a factory clutch?
    Is there any play in the pedal?
    The pedal should have half inch of play, play being the travel of the pedal before it start to push on the clutch.
    Often times, worn clutches have the Master cylinder adjusted out completly to push hard, to compensate for a weak pedal.
    If you have No play, I would have it checked.
Hard clutch
