Results 1 to 5 of 5
    Jan 2009
    gud day sa inyong lahat..i just bought a 02 lancer glx..i wud just like to seek ur advises..ok naman ung takbo,performance,walang leak kaya lang 146 na mileage nya..pinachange oil ko na po.. what else can u advice that i can do to my car? ung supsension po medyo di n maganda..ramdam ko po kasi ung lubak..no po b magandang gawin? tnks a lot..
    Quote Originally Posted by torso man View Post
    since wala namang leaks or major problems, pa check mo na lang suspension mo and replace what is necessary.
    the things that i see:
    a. tie rods
    b. bushings
    c. shocks
    papalitan mo na din tranny fluid. baka nakalimutan mo yun.
    Jan 2009
    tnks 1D4LV.. how much will i spend to upgrade my ride?
    it would depend. are you saying you need to upgrade your ride? or you need to repair the things that are "sira"?
    check mo muna yung mga things that need to be replaced, as the ones i've mentioned above. then kung ok na, then its time to upgrade? ;)
    Jan 2009
    tnks..papaservice ko muna ung kotse and check those you have mentioned..tnks a lot..
need help for my 2002 lancer glx
