Results 1 to 6 of 6
- Mar 2009
- 51
January 23rd, 2013 11:11 AM #1sir/mam ano ba recommended ATF, coolant, brake and power steering fluid, it's due for change na kasi, thanx in advance,
January 26th, 2013 08:30 PM #2
Mitsubishi Montero Sport A/T requires a special synthetic ATF spec called Mitsubishi SP3. Its not available in any of your suking gas stations. So far only its available at Mitsubishi casas and some automotive stores selling Mitsubishi OEM parts. An alternative I recall is the more expensive Motul synthetic ATF (I forgot the full name...). Using generic Dexron type ATF will result to stiff A/T shifts and may damage the A/T (based from a foreign Mitsubishi forum). For Engine Coolant any generic ethylene glycol coolant would do but I would recommend the long life coolant from Caltex. It offers a minimum of 24-months of service life. For Brake and Power Steerig Fluids any DOT 3 spec would do just follow the recommended fluid change intervals.
January 26th, 2013 10:53 PM #3
Correction. Power steering fluids have different specs compared with brake fluids. The earlier DOT 3 spec I mentioned is for brake fluids. Power steering fluid for Montero requires the Dexron II/III spec.
January 27th, 2013 05:24 AM #4
roydok, pwede ba yung atf na sp3 ng mitsu sa power steering natin? nung 40k check up ko kasi nilagay nung mechanic sa casa. pero ang alam ko nga dexron 2 ang gamit.
January 27th, 2013 10:57 PM #5
- Jan 2010
- 28
July 13th, 2013 01:49 PM #6would it be safe to use Mobil ATF220 for power steering? Dexron II ang spec niya.
high idle RPM at engine start
