Results 1 to 6 of 6
    Jun 2012
    patulong naman mga kapwa ko may ari ng lancer itlog...1996 ung akin, 4G13 ang makina, nabili ko 2nd hand. ang problema ko matagal syang mag-init, tapos habang di pa umaakyat sa kalahati ung temp gauge, merong hesitation ung makina, parang mamamatay pag-arangkada o pagtapak mo ng bigla sa gas. pero maganda na takbo pag mainit na. ano kaya dahilan nito? iba ung carb, ibang klase, walang butterfly valve, ang pangkontrol ung pasrang piston nas nakapahiga. mukang electronic din ung carb, hindi bumubuka ung piston pag patay ang makina. meron ba sa inyong nakaexperience nito?suggestions?
    Jan 2009
    It has all the symptoms of a missing or stuck-open thermostat. I'd look into that first before messing with the carb.
    wornout autochoke or due na for an engine tune-up.
    Jan 2008
    paganahin mo yung thermostat mo, then paganahin mo yung idle up ng carb... tapos check mo yung contact point baka may bulutong... check mo din yung timing advancer sa may distributor.. check mo din yung rotor
    walang contact point ang 1996 model 4g13.
    models 1989 and below ang meron.
    Feb 2009
    Quote Originally Posted by leonzerimar View Post
    your car is equipped with a variable venturi carburetor. the wax pellet air bypass valve might be stuck or your engine is running cold all the time. try cleaning the carburetor with carburetor cleaner first. you may be lucky if it was just the venturi plunger moving too slow because of sticky gum and varnish.
engine hesitation when cold
