Results 1 to 6 of 6
- Jun 2012
- 5
June 14th, 2012 10:59 PM #1patulong naman mga kapwa ko may ari ng lancer itlog...1996 ung akin, 4G13 ang makina, nabili ko 2nd hand. ang problema ko matagal syang mag-init, tapos habang di pa umaakyat sa kalahati ung temp gauge, merong hesitation ung makina, parang mamamatay pag-arangkada o pagtapak mo ng bigla sa gas. pero maganda na takbo pag mainit na. ano kaya dahilan nito? iba ung carb, ibang klase, walang butterfly valve, ang pangkontrol ung pasrang piston nas nakapahiga. mukang electronic din ung carb, hindi bumubuka ung piston pag patay ang makina. meron ba sa inyong nakaexperience nito?suggestions?
June 15th, 2012 07:49 AM #2
It has all the symptoms of a missing or stuck-open thermostat. I'd look into that first before messing with the carb.
- Jan 2008
- 4,726
June 15th, 2012 10:09 AM #4paganahin mo yung thermostat mo, then paganahin mo yung idle up ng carb... tapos check mo yung contact point baka may bulutong... check mo din yung timing advancer sa may distributor.. check mo din yung rotor
June 15th, 2012 10:35 AM #5
walang contact point ang 1996 model 4g13.
models 1989 and below ang meron.
June 15th, 2012 11:40 AM #6
your car is equipped with a variable venturi carburetor. the wax pellet air bypass valve might be stuck or your engine is running cold all the time. try cleaning the carburetor with carburetor cleaner first. you may be lucky if it was just the venturi plunger moving too slow because of sticky gum and varnish.
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
