Sa mga may cyclone engines diyan, normal ba na maingay ang cyclone?
Alam ko na kung bakit maingay yung cyclone engine ng singkit ko. May tama na pala yung water pump. Sana nga yun na yung source ng ingay. Otherwise...change engine na...
Tama. Ganun nga sound. Parang may typewritter sa loob. Pero may katok pero hindi regular yung interval. Pinatingnan ko kanina. Yung water pump daw. Pinasilip ko na kasi kailangan din ayusin yung lapat ng cylinder head. May kaunting leak kasi ng langis. Malalaman ko details mamaya from my mechanic.
maluwag na yung nuts ng rocker arm mo.
try tappet or valve clearance adjustment, using feeler gauge sa marunong na mechanic.
goodluck sir and welcome to tsikot.com.
Yung '95 itlog ko din maingay ang makina, cyclone engine din po to. Parang mahangin yung tunog niya.Nt sure kung anong psource nung ingay pero baka may mga inputs kayo?
Ok na pala cyclone engine ko. Pinaadjust ko yang tappets as suggested by zero. Pina-adjust ko rin timing. Pina-overhaul ko rin yung power steering pump. Pinalitan ko lahat ng belts(except timing belt). Ayun mas tahimik na yung tunog. Yung ingay ng engine eh yung natural na ingay na ng tappets. Sabi ng mechanic ko ganun daw talaga dahil may clearance talaga yung tappets.
Ang medyo weird lang yung ingay kapag kaka-start pa lang. Tsk tsk tsk tsk yung tunog. Sabi ng mechanic ko sa belt lang daw yun. Nawawala rin naman kaya di ko na pinapansin. Next project ko yung transmission.
Just this morning, a mechanic road tested my Elantra 94 model. The engine has similarity to Mitsu's cyclone. My complaint is the typewriter "clickity-clackety" sound which is faintly heard at highway (flat road) driving but becomes very loud when climbing up, when the car demands lots of torque.
The mechanic said the hydraulic adjuster might be the culprit. This component is responsible for the proper opening and closing of the valves. Although, I have no way to be sure. All I'm certain is the noise is generated from the valve mechanism. Since I have to use the car today, I'll go back to the shop next week to have the repair jobs done.
I am really concerned because my FC has suffered. At city driving with stop and go traffic, FC is worse at 6~7km/L. Pero kung highway naman at super hataw mode pa, I can reach 17km/L.
Hi smoke!
Actually ok lang naman na ganun ang setup. Ganyan ang ginagawa kapag sira na yung thermostat sa radiator. Yun nga lang maingay palagi dahil gumagana parati yung fan. Ganyan yung set up sa lancer ko nung nakuha ko. Pinalagyan ko ng bagong thermostat sa radiator para gagana lang yung fan kapag mainit na talaga yung engine.
Baka dun lang galing yung hangin na nabangit mo.
[SIZE=4]hello every1 newbie lang po ako dito. i have a few questions lang po about cyclone engine. i have 92 model lancer glxi singkit. ano po ba ang standard fuel consumption nito? kc parang maaksaya na yung sakin at nag ooverheat mahina ang aircon. pls help me email nyo ko or add sa YM katelaigo*yahoo.com tnx madlang pipol..[/SIZE]
