Results 1 to 10 of 20
November 29th, 2010 11:40 AM #1
I had my rig serviced at Diamond-QA last November 20. All my concerns* were attended to
. And most of all, they respected me in the choice of oil fed to my beloved engine
*1) Steering wheel in the 1PM positioned - corrected to 12 o'clock.
2) Loose fog lamp cover - corrected.
3) Rear "ek-ek" sound - corrected.
4) Uneven stance - I will let the service crew measure it in front of me for my reference.. I measured it myself and I got the ff--front error is 5mm and the rear is about 10mm; I dont know lang how flat my surface is when I did the measurement, reason why I will witness the measurement at the casa duirng my 5,000km check-up. The 5mm and 10mm based on the Strada forum is w/in the tolerance limits....
As expected, the free stub was honored.
No regrets whatsoever of not doing the PM at Citimotors-Makati-- CITIMOTORS-MAKATI hindi ko papahawakan sa inyo ng mg Mitsubishi Cars ko
November 29th, 2010 04:16 PM #2
November 29th, 2010 05:42 PM #3
It is in Quezon Avenue. Coming from Nagtahan/UST, Diamond-QAve is in your right if we will be coming from Espana.
Landmark would be after Araneta intersection, you will first see TOYOTA-QAve then NISSAN-QAve then DIAMOND-QAve; Diamond-QAve is now being renovated kaya you need to yield and slow down if you see Toyota -- pag lagpas mo ng small bridge, Diamond na ito.
Note: wala itong malaking sign since it is under renovation kaya bagalan mo ang speed mo..
Diamond-Valle Verde is an option for you as well; it is recommended by Club Strada and in the Montero Forum too; it is to your right coming from C5. The landmark is pagbaba mo sa bridge ng Pasig yield ka na rin to your right... the site is before Tiendesitas. Tiendesitas is to your left ha..
Sa South naman -- based on the Forum, Citimotors-Las Pinas okay raw. Taga north kasi ako pards kaya I can not provide actual feedback.
A 70/30 water to coolant mix may improve cooling efficiency but that's at the cost of less...
Coolant...
