Results 1 to 2 of 2
- Aug 2008
- 8
December 19th, 2010 09:17 PM #1Mga sir help naman po. Mitsubishi Lancer Gli 1995 model po ang kotse ko. ngayon medyo may napapansin po akong kakaibang nangyayari. eto po yon
Every morning when i will go out and start the Engine. yung "Check Engine" will lights up for about 3 to 5 seconds. medyo bago po itong nangyayari kasi previously bago ko po i-start ang engine e i wait for the check engine to goes off then tsaka ko start, then hindi nagla-light ang check engine. but now kapag naka-rest ng at least 3 to 4 hours yung kotse lagi na lang umiilaw ang Check Engine for at least 3 to 5 seconds pero so far wala naman pong nagbabago sa takbo ng makina.
i will surely appreciate all the inputs and helps ninyo.
- Dec 2010
- 87
December 19th, 2010 11:25 PM #2check engine >> mulfunction indicator lights. that mean may na sesense na fault ang internal diagnostic circuit ng Control unit ng otto mo. kaya iilaw ang check engine to have your attention. It may be emmission system of engine management system. kadalasan naman pag ganyang namamatay agad intermittent ang problema nyan. ang magandang gawin mo, ipa scan mo na lang. para malaman mo ang trouble code nyan. or subukan mo muna alisin ang battery terminal for at least 30 second para ma clear ang fault nya. tapos check mo ulit kung ganun pa rin. pa scan mo na.
Yes Yes squeaking sound is heard when shifting only
