Results 1 to 10 of 10
- Mar 2009
- 4
August 3rd, 2009 12:35 PM #1Mga sir tnong ko lang po kung may nakaencounter n ng ganitong problema sa 4D56 diesel engine, i have a 1998 mitsubishi adventure, nagooverflow yung oil nya sa may top cover pag mainit n, nagpalit n po ako ng air filter pero gnun p din, ano po kya ang problema nito? thanks in advance!
August 3rd, 2009 01:26 PM #2
nacheck nyo ba ang oil level ninyo? possible na baka sobra sobra ang langis na nasa loob ng makina.
- Mar 2009
- 4
August 4th, 2009 10:19 AM #3oo sir e nacheck ko nman yung oil level ok nman po, ano p po kya ang mga dpat ko icheck...TIA
August 4th, 2009 10:27 AM #4
no text speaking po sir. bale ganito, paano mo nasabing ok ang oil level mo? sure ka ba na at most nasa 1 o 2 guhit before the full line ng dip stick mo? another thing, baka rin kasi yun mga gasket mo eh sira na din, yun ang 1 mo pang dapat i-check
- Mar 2009
- 4
August 6th, 2009 10:15 AM #5ok sir idouble check ko po ulit yung oil level, then tnong ko lng po kung yun lng yung mga possible problem nya kci nagwo-worry ako bka po kci kailangan n ng overhaul e, thanks po ulit sa reply.
- Mar 2009
- 4
August 10th, 2009 07:46 PM #8
bro check mo yung gasket nung cover saka sa bandang likod yung halfmoon na gasket din.. kadalasan yan ang cause.. halos every year nagpapalit ako nyan..
August 10th, 2009 07:47 PM #9
- Jul 2010
- 5
July 9th, 2010 10:06 PM #10palit ka ng half moon seal sa likod ng valve cover gasket tapos palit ka na din ng valve cover gasket then palit ka na din ng side cover gasket
high idle RPM at engine start
