Results 1 to 20 of 24
    May 2010
    Hi all,
    i'm currently canvassing for a Fully Synthetic Engine Oil for my Strada. I have been using Motul CRDI Specific but recently had issues with my EGR and emission. I think its because this oil isn't API CI-4 rated (designed for EGR).
    To date, i have not found an FS engine oil that is both CI-4 rated and at the same time ACEA A3/B4 rated. A lot of users have been suggesting FS oils that are CI-4 rated but these are (usually) ACEA E4/E7/E9. A3/B4 is best for the Strada/Montero engines which are Direct Injection engines.
    Is there any such Fully Synthetic oil that is both API CI-4 rated and ACEA A3/B4 rated? Thanks!!
    P.S. there are a lot of Mineral oils that are rated as such, but i prefer to have FS for the best performance.
    Mar 2005
    Sir ano naging problem sa emissions and EGR nyo? CRDI specific din gamit ko sa Montero and Santa Fe. No issues encountered so far.
    Aug 2003
    You can use a variety of oils for the Strada available in both fully syn, semi-syn and mineral as long as they are CI-4 or up. Hindi naman kailangan ng specific brand. But I do use Mobil 1 Turbo diesel truck on my Montero.
    The emissions/EGR problem that plagues the Montero/Strada is usually the result of using diesel fuel from the big 3 which is only Euro II. Try using Euro IV diesel (available at Unioil and select Eastern Petroleum) and search on EGR blanking.
    May 2010
    Quote Originally Posted by ek2jayvee View Post
    Thanks for your comment. so in your case, ok lang kahit hindi A3/B4 rated yung oil na supposedly for direct injection? Ok ang mga Mobil oil na 'E' ang ACEA rating? and yes, next step for me is to have my EGR system cleaned. thanks again
    May 2010
    Quote Originally Posted by jmpet626 View Post
    Pasang awa sa emission test ng LTO. and thats right after the 80k check up wherein oil filter, fuel filter and air filter was changed. CRDI specific oil and Petron Turbo diesel din ang gamit. With all of these, disappointing na pasang awa lang sa emission test.
    when i called Diamond, sabi baka EGR ang problem. and when i researched, hindi designed for post-combustion technology (such as EGR) ang Motul CRDI specific. Its not CI-4 rated.
    Mar 2005
    Sakin Blanked EGR ko, Unioil Euro 4 fuel and I add 2T to my diesel.
    Manual says API or ACEA, not both. If you want to satisfy what Mitsubishi wants, then use Mitsubishi TurboXP.
    May 2010
    Quote Originally Posted by nivraarvin View Post
    ah talaga? in my manual, 2008 Strada GLX, walang 'or' na sabi. Actually CD lang ang sabi sa API. Kaso, commonsense would dictate na dapat CI-4. thanks for your comment.
    May 2010
    you might say that you've said it all along. however, when i started this thread, i had the old turbo XP in my mind. i didn't know they had a new one which had CI-4 and A3/B3 ratings. nonetheless, thanks for suggesting Turbo XP. i ended up using it.
    Quote Originally Posted by Avaris008 View Post
    Sir you might wanna try Mobil 1 TDT. Been using it for the past 4 years and have clocked 120k na on my odo. Very satisfied naman ako until I totaled my ride. You can go as high as 15k intervals before changing oils pero dapat every 5k and 10k palit Lang ng oil filter and a little top up. With regards to the ERG, you can always block it/blanking or just have your EGR cleaned every 2 years and use quality diesel fuels. HTH kahit medyo late na.
    Sep 2011
    Hi all,
    This website might help you a bit :
    Understanding engine oil designations | Motoring | RACQ
    In a nut shell these 3 statements in the document can clear up things for you:
    1. As stated API is for the Americans and ACEA is for the Europeans.
    2. The document also tells us that
    "ACEA standards recognise that European engines differ from US (style) engines in both their design and operating conditions and that the demands on their oils are also different. This requires the oils used in European engines to be unique and consequently, the classification system for them also needs to be unique. For this reason it is difficult to compare the common API classification and ACEA standards, as the test sequences for them are quite different."
    3. and finally:
    "While it is common for Japanese vehicle manufacturers to specify engine oils in terms of API oil service classifications, some applications use JASO ratings. This is because API rated oils are not always applicable to Japanese engines, due to variations in engine design and exhaust emission requirements compared to the American engines for which API oils were originally developed"
    Its nice to find an FS oil that can satisfy what your looking for (do update us if you find one) but if you can't find one I think its safe to say that at the very least your FS oil should pass the API requirements of your rig since it is a Japanese engine unless it has a specific JASO ratings specs
    Apr 2011
    two things...first, as suggested, you can opt to use only what mitsubishi recommends which is turboxp. that is what i use for my glsv....second, find somebody who can have your car registered non apperance, and shall also provide smoke emmission test result for you...expect to pay extra though for the service...
    Your emission problems are probably caused by the fuel you use. Try to avoid the big 3. Use Unioil, PTT, Eastern Petroleum, or Seaoil.
    Also, try to add 300ml 2t (2 cycle oil) every time you fill up with 60L diesel. This will also lessen black smoke during hard acceleration.
    As far as I know, 2008 GLX does not have a catalytic converter. You can use high zddp motor oil.
    Motor oil can only affect your emissions if you have a high oil consumption. Motor oil is sealed from the combustion chamber(of course, very small amounts will still leak inside).
    Quote Originally Posted by metslgx View Post
    why do you have to go to fixers and have a non appearance smoke emission test done? pwede naman ayusin yung problem para hindi bumagsak sa emission test.
    Apr 2011
    boss dont get me wrong, i have no problem with smoke emmission and we should all address this problem when we all have concerns with our rides. I do. the smoke emmission testing is a separate issue and mostly diesel car owners are the ones falling as victims of this racket. kung hindi ba raket to at kung properly monitored and implemented ang purpose nito may bus kaya sa edsa? or to paraphrase, ilang bus jeep at truck lang kaya ang bumabyahe sa edsa o anumang lansangan ngayon? so reserve this to to the government sir...peace...
    Nov 2014
    Guys, I recently pulled out my Strada from casa and decided to have it serviced outside. Before I was using turbo XP at 1K, 10K and 20K PMS. Now, I'm on my 30K and put on Mobil Delvac 1 5W40. Have anyone of you tried extending this engine oil to 12 or maybe 13K kms with OEM oil filter changes at around 6-6.5K kms?
    Apr 2012
    Try ZIC RV 10w30 Fully Synthetic na siya.
Synthetic Engine Oil for Strada/Montero (Direct Injection Turbo CR Diesel w/ EGR)
