Page 96 of 377 FirstFirst ... 46869293949596979899100106146196 ... LastLast
Results 1,901 to 1,920 of 7539
    Jul 2016
    #1901
    My unit veers to the right when I let go of the steering wheel. I did wheel alignment at Motech pero parang mas lumala yung pag veer to the right. My casa suggests I go to a casa with wheel alignment.
    Sino na po naka ayos ng issue na to?
    Mar 2004
    #1902
    Quote Originally Posted by danisonco View Post
    Very few wheel alignment centers have updated data on their computer. Even less have the right specs for 2015-2016 PPVs.
    Jul 2016
    #1903
    It is advisable na sa casa mag pa wheel alignment for new gen cars equiped with Steering wheel angle sensors like this montero.
    You need to calibrate 0 of angle sensor to 0 of steering wheel and 0 of alignment.
    Jul 2016
    #1904
    Unbelievable price... makes all the competition looks expensive.
    Also pricing makes room for the 4x2 GT variant.
    Wow, mura nito. Monty talaga sana kukunin ko 2months ago while shopping for SUV. Mivec 8-speed baby!! It was 1.4M that time pa cash ung base model.
    Sayang lang, Im 6'2" in height kasi at sobrang naturn off ako masikip sya compared sa eve. Ung right knee ko nagka "pasa" after 30mins of test drive pa lang.. Nakadikit sya dun sa V shaped na center console. And ung sa 3rd row seat literal di talaga ako kasya. Sa eve lang ako nag kasya when it comes to 3rd row seat since movable ung 2nd row at malaki head room. Sa fort naman kasya rin ako sa 3rd row when it comes to leg room pero head room is wala na. Literal nakayuko ako.. Hehe..
    Mar 2016
    #1905
    Same experience, ako hindi kumasya sa Ferrari California hindi lang pasa inabot ko black eye at bukol sa ulo pa. 15mins lang yon ah hays. kaya motor nalang kesa kotse.
    Jul 2016
    #1906
    Ask kulang sana kung anong gamit na Engine Oil sa 2016 Montero?
    Ang alam ko kasi fitted sya with DPF thus requiring special type of OIL?
    nasa 8K na kasi ODo ng Gamit ko Montero, but upon checking almost nearing the below mark na iyong dipstick.
    I'm thinking twice kung dadalhin ko pa sya sa Casa for inspection (10K pa kasi chageoil nya) or kung pwede ko syang top-up na lang muna?
    (sorry first time diesel car owner po, di rin po techy sa makina)
    Jul 2016
    #1907
    Quote Originally Posted by Macross View Post
    Please check you owners manual po sir. 99% indicated naman po dun yun regarding oil grade to use.
    Better clear it with your SA sir, alam ko po sir alang DPF ang local unit ng all new monty. Ala rin po kasi syang 02 sensor, I might be wrong though.
    Jul 2016
    #1908
    Quote Originally Posted by Janemar View Post
    Thanks for the Reply.
    The Manual states that Diesel Powered Units without DPF can use ACEA A1/B1,, A3/B3, A3/B3, A3/B4 or A5/B5 Service clasifications
    Diesel Powered Units with DPF should use ACEA C1,C2, C3, C4 (which from initial research are low SAPS oil)
    Lahat ba ng 2016 Model ng Monty without DPF?
    Mar 2004
    #1909
    This is not true. Some cars do not have 0 degrees setting for camber adjustment.
    Mar 2007
    #1910
    Na-mention dito sa thread, just back read. IIRC it has something to do with the stabilizer bar.
    #1911
    Quote Originally Posted by firehawk30 View Post
    Hi just want to ask if there is a way to turn off the fog lights acting as DRLs for GLS model? Thanks
    Sent from my D5833 using Tsikot Forums mobile app
    bunutin mo sir yung Fuse sa loob ng engine bay. mag off po yan.
    #1912
    Mitsubishi Oil ang gamit nila sa CASA. sakin kase Full Syn ang gamit ko.
    According to sir Zix
    Wala dpf ang new monteros..
    Jul 2016
    #1914
    Yes po sir wala po. Maverify nyo po if may nakatusok na mga sensors just after turbo downpipe. Usually pag mag DPF, may O2 sensor and EGR sensors sa exhaust...
    Jul 2016
    #1915
    Hi Sir, sorry if di ko na clear mabuti.
    When I say 0, it means your alignment is on the spot/at sync/center/on point with what is the recommended aligment(toe/camber/caster) of manufacturer.
    Again, if the angle sensor is not calibrated to the new "0" of alignment(not literally saying na "0" ang camber/toe or caster ahhhh, Im just saying spot on na alignment.)
    Example after you done your alighment and test drive at good year servitek and all is well na pero di na calibrate ang steering Angle sensor afterwards, ECU thinks your steering wheel is turning say 3degrees off even though in actual, your perfectly tracking dead straight on the road na at 100kph,etc...
    Now. Depending on the vehicle on how it uses this angle sensor, example baka sa all new monty di naman mahalaga since ginagamit lang sya sa reverse camera park assist to guide you and show directional line sa screen pero on some ford vehicle s na nag papark mag isa and may lane assist, critical po ang calibration na ito.
    Hope that clears things up.
    #1916
    Quote Originally Posted by sabelito View Post
    Ask ko lang mga sir. Normal lang ba na hindi stable ang idling ng motero pag on ang ac? Sa everest kasi naka on man ang ac o hindi stable ang idling niya.
    yes.. ganyan talaga sya... nag automatic idle up sya pag nag e engage ang aircon compressor.
    Jul 2016
    #1917
    Quote Originally Posted by pakjun View Post
    Hi sir, what about the stabilizer bar? Can't find it in the thread.
    Jul 2016
    #1918
    Thanks po sa Reply at Info...
    Bakit po kaya marketed ang Montero na Clean Diesel ... possible po ba iyon kahit walang DPF?
    Jul 2016
    #1919
    Thanks po sa reply.
    If wala naman po palang DPF montero, can I just topup with locally available engine oil? Ano po kayang magandang brand and type?
    Jul 2016
    #1920
    Thanks po sa reply.
    Because it is Euro 4 already vs. Old monty na euro 3 lang. Boasting clean term. Maybe thats why, marketing strategy.
    Anyway, on my daily beater 11year old, 05 model matrix diesel(euro 4 engine but no DPF,) motul crdi lang ako lagi change oil at 8T kms. 260T kms on the clock. Still runs on orig turbo, orig timing chain, di pa nabuksan oil pan and makina. No smoke and still achiving same topspeed since bnew. May turbo whine na nga lang, sign of high mileage turbo... Antayin ko na lang mag blue smoke or loss power before ko palitan turbo.
2016 Mitsubishi Montero
