Page 426 of 754 FirstFirst ... 326376416422423424425426427428429430436476526 ... LastLast
Results 4,251 to 4,260 of 7539
    Mar 2004
    #4251
    Ford Everest has active noise cancellation ...
    Quote Originally Posted by Underpar View Post
    My 6 months old Monty keeps on reminding me regarding the periodic maintenance that I need to do which I already did a month ago for the 5,000 kns PMS.
    I think I have read ready somewhere in this thread on how to remove the reminder from the dashboard and HU. I tried backreading and I wasn't able to find the page. Anyone here who happen to know how to do it?
    Call the dealer and ask for the code ... tell them you have no time to go back for code reset ...
    Dec 2012
    #4252
    Saw someomes post on FB. Nkapaginstall n sya ng surround camera / birds eye view monitoring. Last time checked sa winterpine wala pa daw sa pinas yung ganun feat. Dami na nagiinquire info dun sa FB user pero wala binibigay tip. Anyone knows saan meron nito?
    Dec 2012
    #4253
    I saw someones post on FB. Nkapaginstall n sya ng surround camera / birds eye view monitoring. Last time checked sa winterpine wala pa daw sa pinas yung ganun feat. Dami na nagiinquire info dun sa FB user pero wala binibigay tip. Anyone knows saan meron nito?
    Nov 2014
    #4254
    Speaking of camera, is there a way to change the color settings of the backup cam? Nalalabuan ako comparing it to my Mazda 3. Halos black and white na siya.
    #4255
    I use 3280 to reset my HU for my 2012 Montero. I'm just not sure if they changed it for the 2016-17 model.
    Dec 2009
    #4256
    To current owners of montero,
    Do you tend to forget to release the park brake every now and then because its no longer a lever switch?
    Sent from my GT-P3110 using Tsikot Forums mobile app
    Mar 2017
    #4257
    Yun din concern ko for the new owners ng naka electronic parking break. Aandar ba ng pilit pag kunwari naka engage tapos nag gas ka like sa lever type? O hindi talaga siya aandar na parang naka neutral ka na umapak sa gas? Curious lang.
    #4258
    aandar syempre like a normal parking brakes would. I don't forget because I made it a habit ever since not to begin driving when I see any warning light lit.
    but I can see others having a greater tendency to forget. I'm not much of a fan of electronic parking brakes(and push to start) but I appreciate the coolness factor.
    siguro ang advantage, always same level of pressure all the time. unlike yung mechanical na may tendency to be pulled too hard (or too little) at times.
    Jan 2013
    #4259
    Like any other new thing, Sa umpisa you have to remind yourself of the electronic park brake. But eventually you'll get used to it especially if you drive the Montero on a daily basis.
    Ako naman ang problema ko, minsan i look for the electronic park switch even when I'm driving the other vehicle which has the traditional lever. And vice versa.
    Sent from my ONEPLUS A3000 using Tapatalk
    Mar 2017
    #4260
    Quote Originally Posted by wavecxs View Post
    aandar syempre like a normal parking break would. I don't forget because I made it a habit ever since not to begin driving when I see any warning light lit.
    but I can see others having a greater tendency to forget. I'm not much of a fan of electronic parking break (and push to start) but I appreciate the coolness factor.
    siguro ang advantage, always same level of pressure all the time. unlike yung mechanical na may tendency to be pulled to hard (or too little) at times.
    I see. Ano kaya reason why hindi nilang ginawang ma bypass yung pagapak mo sa gas while on drive. For me, dapat siguro pag naka engage yung parking break kahit anong gas mo dapat di aandar. Dapat parang naka neutral lang tapos nag gas ka yung response ng car.
2016 Mitsubishi Montero
