For business use ... Montero Sport ... it's diesel and has a more robust chassis ... or buy the Mitsubishi Xpander and get a used diesel vehicle for business use ...
"go for the more robust car" is my default answer.
you can always get another wife.
BWAHAHAHA...!!
joke, of course (the wife part, not the car part).
errr... what type of business would that be...?
would it need a robust vehicle, or just about any vehicle, even a motorcycle, will be adequate?
for aftermarket wheels, based on your experience what's the lowest offset we can go without needing to add fender flares? just wondering also kung may wheel show off thread ba dito for wheel and tire upgrades sa 3rd gen montero.
guys ano pinag kaiba ng gls at 2wd 2017 sa 2018. nasa bank kasi ako ngayon dalwang year ang lumabas sa system nila
Sent from my A1601 using Tapatalk
Just to answer your question...
Kung montero at xpander lang talaga ang pagpipilian, montero na.
Mabigat ang school supplies. Notebooks at bond paper pa lang, dapa na ang sasakyan mo.
Mejo off topic, pero if i may suggest, buy a separate vehicle for divisoria purposes.
We are on the same line of business. (sana hindi ka namin competitor haha)
Malalaspag ang personal car mo kung kakargahan mo ng school supplies.
Ilang kilos lang ang payload ng montero, 500kg? 700kg?
Most light duty trucks (passenger van type) can have 2000kg payload. These are still considered class1 sa toll fees IIRC.
Approx 4 byahe ng montero mo, 1 byahe lang sa light duty truck mo.
With proper maintenance, these can last for at least 10 years.
2 isuzu trucks namin, isang 15 years at isang 20 years. Partida 2nd hand pa namin nabili pareho yun at yung isa dun ay converted to left-hand drive pa.
Masasabi ko na matagal na kaming nag-ROI na kami dun sa mga trucks na yun.
Do the math na lang para sa situation mo.
If using all 7 seats frequently, better look at the Toyota Innova ... better 3rd row seating ...
I don't seem to find any topics for 2018 Montero Sport, MODS you may move my response to the correct one.
here's my issue with the 2018 Monty, hindi sya accurate pag ni set mo yung GPS sa isang lugar na dapat puntahan mo. like for real I am from Cebu and if ni set ko yung GPS to Banilad Town Center it will go to a different path even going off the City.
kaya kadalasan gumagamit nalang ako ng google maps if off City mas accurate pa then waze if within the City lang. nagkakaganitoh din ba yung monty nyo? even with the previous gen?
Question regarding sa auto climate control.
Pagni-set ko to Auto, nag-o-off kasi yung recirculation button light? Ibig sabihin po ba posibleng pumasok yung outside air pag naka-Auto mode?
Yun kasi main reason ko kung bakit manual setting lang ako parati.
guys i'll just leave this here para sa mga nagtatanong parin about the changes in the 2018 montero
Based on my experience, even after you have set it based on the instructions on the manual, once you turned on the AC using the AUTO, there are times that the RECIRC automatically turns off, I only start noticing it when I am beginning to smell fumes from inside the cabin. Anyways, that's good to hear that the newer models doesn't turn off anymore when you use AUTO, mine is 2016 model.
