Page 320 of 377 FirstFirst ... 220270310316317318319320321322323324330370 ... LastLast
Results 6,381 to 6,400 of 7539
    Nov 2017
    #6381
    Quote Originally Posted by dos2 View Post
    Maybe not all. Insurance claimed from BPI M/S (insurance arm of BPI bank), pumayag naman sila na sa Toyota casa gawin.
    good for you sir, me experience ako ganun ginawa
    Aug 2017
    #6382
    Quote Originally Posted by go-to-guy View Post
    Got a few questions I hope you guys can help me with.
    1. Does the Infotainment screen always begin with the tire pressure info when you turn it on? Or can this be configured?
    2. Is there an instruction on how to use the Navigation? It's kinda hard to set Home.
    3. When not setting a destination on the navigation but you press it (Navi) so that it will appear/display on the screen, it goes to the tire pressure screen again after awhile. Is that normal because no destination was set?
    4. Can the Navigation be updated (online)? I noticed it still had a restaurant that's closed already since a few years ago.
    1. The default screen of our HU is tpms when you switch it on.
    2.yes its easy, when you go to navi and lock to your home location or type your home address then after locking in. Sa setting you can find set location HOME then click yes.
    3.yes it will go back to screen default setting after few minutes.
    4.yes you can update via inav. But much better sa winterpine na lang. SD card updating every 3mos.
    The black booklet of montero which has owners manual,HU manual and pms card inside.
    Hope it helps.
    Sent from my iPhone X using Tapatalk
    Nov 2014
    #6383
    Quote Originally Posted by montro View Post
    Hope it helps.
    Thanks alot sir! Nice to know it can be updated[emoji106]
    #6384
    Does the 4x4 MT variant have a gear level indicator sa dashboard? Ive seen youtube videos na merong ganito. Id like to install/activate on my unit (4x2 MT) sana. Madalas ako magkamali sa 1st gear, sa 3rd gear ko naipapasok.
    Nov 2003
    #6385
    May nakapag try naba mag install ng underseat sub sa montero ank brand maganda at ilang inch? Saan maganda magpa intall and how much salamat
    Aug 2010
    #6386
    Quote Originally Posted by mar04 View Post
    Anyone nag update sa iNav? File not found nalabas saken.
    I always did from there website, ako lang nag update ng map ko, very easy lang yan. You need to extract muna na download using winzip..then lagay mo yung SDcard mo s PC..if walang micro sd card inserter yan PC mo you need adapter, one na detect na yung SD card mo, open mo yung folder kung saan na extract yung na downlaod mo, the click mo lang yung Updater.exe..follow instructions. Ganun lang yan ka simple..may nadownload n instructions s website nila for manual updating. Now I'm enjoying there new Update, totally NEW software, maraming nabago sa Interface and design but I like it.
    Aug 2016
    #6387
    Penge ng exact link pre... TIA...
    Eto ba yun:
    Update Instruction
    Quote Originally Posted by jessgab View Post
    Dec 2017
    #6388
    Yun bang micro Sd card ng HU nyo ay may seal on top?
    Oct 2009
    #6389
    Quote Originally Posted by chitomaru View Post
    Eto ba yun:
    Update Instruction
    My HU will be replaced as suggested by winterpine under warranty, nag tanong lang kami about navi ginawan na agad ng request for replacement..
    Jan 2018
    #6390
    Quote Originally Posted by Raynim999 View Post
    43k is way too expensive. I got mine around 30k..
    Sent from my SM-G950F using Tsikot Forums mobile app
    HI Sir,
    Saan ako pwede mag reklamo if ang binibigay sakin na Car Insurance ay hindi makatarungan? Policy daw ng Bangko yun pag Mortgage daw ang Car haist
    Mar 2011
    #6391
    Tanong ko lang po, na-turnilyo kasi yung rear left tire ko. Ang gamit ko ngayon is yung spare tire at ginawa kong reserba nalang yung nabutas pagka vulcanize. 11k KM na yung tinakbo bago nabutas. Kaka rotate lang din ng mga gulong last 10k PMS. Ok lang po ba kahit mas bago yung isang gulong? May nagsabi kasi sakin na dapat pantay yung thread ng mga gulong na gamit ko or atleast by pair pag magpapalit ng gulong. Thanks po.
    Aug 2017
    #6392
    Quote Originally Posted by regjesmom View Post
    Yes it has a seal. When I went to winterpjine to replace my HU before. They remove the seal to get the sd card and told them not to forget to put a new seal they said no need to put one 'coz its only for mitsubishi plant purpose only.
    Feb 2011
    #6393
    Even my SA in diamond motors VV removed the sd card seal saying it will only gather or attract dust
    Aug 2017
    #6394
    Quote Originally Posted by juni923 View Post
    If you can look your manual there's a pattern on how to rotate your tires if you dont like to use the spare tire and there's a pattern also on how to rotate your tires including the spare one.
    Aug 2017
    #6395
    Quote Originally Posted by alv555 View Post
    They put seal in the plant to determine sd card installed sa hu.regarding warranty still 3yrs pa rin as per winterpine even no seal. Kahit magpaupdate ako sa kanila ng sd card quarterly they didn't put one.
    Jul 2006
    #6396
    Hello mga sir,
    Tanong ko lang po kung meron sa inyo naka custom-fit na 3M nomad matting sa montero 2017. May na search ako sa internet pero hindi daw 3M. Sa casa naman parang nasa 13k+ po yata.
    Also, meron din po bang naka cargo tray sa inyo? Naghahanap ako ng full tray for my luggage or gears sana. I saw 2 types: (1) full tray na 1 whole piece, then meron din (2) 5-pc full tray. I want to know your feedback on the 5-pc full tray kung hindi mag leak ang water from wet gears/bags.
    Salamat po ng marami.
    Oct 2009
    #6397
    May bayad ba bro update ng sd card? Sa akin kasi they asked 1k and tinuruan din ako paano mag update unfortunately nakalimutan ko naman gawin.
    Dec 2017
    #6398
    Thanks, so madali lang talaga ang mag update as I did in Fortuner before. need model ng HU lang.
    Dec 2017
    #6399
    Quote Originally Posted by twinkiddoe View Post
    Hello mga sir,
    For matting sa Ace meron for New Montero but not 3M, 9K.
    Jun 2012
    #6400
    Hello mga sir,
    Sa lamson 6k. For montero talaga ang shape
    Sent from my SM-A9000 using Tapatalk
2016 Mitsubishi Montero
