Results 4,751 to 4,760 of 7539
April 27th, 2017 12:29 PM #4751
I only had my OCC installed recently on my Navara. It is running a lot smoother now. Methinks the oil vapor from the crank case was the cause. It is 9 years old and a lot of oil was washed out when they cleaned the IC.
For me the best one is still Provent. The design jist won't let any oil into the outlet, and having a drain at the bottom, you can plumb the oil back to the crank case or drain the oil if you prefer. It also has a bypass valve which opens to let the air through just in case the filter gets clogged.
- Jul 2016
- 1,178
April 27th, 2017 01:24 PM #4752Yung alterra namin mag 8 yrs na sa nov. More than 100k natakbo wala occ. My innova going 4.5yrs 80k mileage wala rin occ. Di naman ma usok at nag ka problem.
Sent from my SM-J500G using Tsikot Forums mobile app
April 27th, 2017 02:03 PM #4753
- Oct 2008
- 42
April 27th, 2017 02:20 PM #4754
April 27th, 2017 02:49 PM #4755
Necessary is such a relative term. If you want your car to last for a really long time and to run as smoothly as possible, I suggest it is worth a look. You only need to unplug your breather hose to see how much oil is dripping there. More damning is the intercooler. You'd be surprised at how much oil collects there after a few thousand Kms.
If you are the sort who sells after a few years, it may not be necessary.
As to why they are not fitted from factory, cost is the number one consideration. And the possible issues occuring a long time past the warranty period makes it unnecessary for the manufacturer.
- Oct 2013
- 1,181
April 27th, 2017 03:05 PM #4756Hypothesis mo lang yan bro. Wala oil catch can majority ng mga sasakyan na tumatakbo, turbo charged or naturally aspirated. Baka nga walang 1% ng population ng isang car model ang meron nakainstall, pero bakit takbo pa rin ng takbo. Susme, it all boils down kung paano ka mag maintain ng sasakyan mo. May OCC ka nga balahura ka naman mag palit ng oil. Di mo yan kailangan, all you need is proper change oil and follow the suggested periodic maintenance.
- Nov 2005
- 1,078
April 27th, 2017 03:12 PM #4757Long time ago, yung mga sasakyan na binebenta sa Pilipinas (hello lancer boxtype) walang rear passenger seatbelts, at walang side mirrors (except for driver side lang ata).
So were seatbelts and side mirrors useless accessories, considering they were not "factory installed" back then in the Philippines? I don't think so.
April 27th, 2017 03:15 PM #4758
- Oct 2013
- 1,181
April 27th, 2017 03:15 PM #4759Long time ago yun, di pa uso ang "lawsuit". At di pa uso ang crash test dummies.
Ngayun na pwede mo na isimulate kahit performance ng makina at pwede mo i-burn in test mo ang makina habang sangkatutak ng sensors nakasalpak, bakit di pa rin nila maisipan amg factory install nyan?
Lahat ng feature halos ilagay na sa sasakyan, bakit di yan ilagay? ngayun pa na golden age of mass production, kulangot lang yan.Last edited by vvti2.0; April 27th, 2017 at 03:18 PM.
- Feb 2017
- 62
April 27th, 2017 03:16 PM #4760
Thread was made nung 2018 pa po sir.
