Page 126 of 138 FirstFirst ... 2676116122123124125126127128129130136 ... LastLast
Results 2,501 to 2,520 of 5877
    Quote Originally Posted by gh0str1d3r View Post
    Which is better in general AT or MT GLS?
    that depends.. are you using it in the metro, or are you using it in tagaytay highlands or baguio? there are pros and cons..
    then, there's this... are you a diehard MT guy, or a diehard AT guy?
    in general... MTs last longer, while ATs offer convenience..
    AT versus MT has always been a presonal choice..
    Aug 2013
    also, ATs are of high maintenance, especially sa transmission fluid.
    how about you, sir dr. d, are you a diehard MT guy, or a diehard AT guy?
    Aug 2013
    double post.
    Is AT, madaling masira? yung CVT po b ng mirage ilang kilometers bago I-check and condition? or ilang kilometers bago palitan yung belt? Yung belt po nito d katulad ng scooter noh...steel or chain po ba toh?
    Paki sagot po. I'm really considering getting the CVT cause of the convenience at CVT manages FC efficiently compare to MT, and masmalaki discount ng CVT compare to MT
    there's a saying... if you may buy with confidence a used MT... not so a used AT or CVT.
    as mentioned above, ATs need more maintenance than MT.. but as long as maintenance is done religiously (it's in the owner's manual and it ain't cheap), and they are not abused, they do last long.. but hey! some MTs can out-live the engine.
    today's CVTs are, i believe, much improved from the previous ones.. just how long they will last, i do not know.
    but my thoughts are, if you like AT or CVT, then go get a new one!
    what do i have? i used to have a 2003 CVT.. no problems.
    today, i have both MT and AT.. i like them all. sometimes, what i drive out is based on what's easier to get out of the garage that morning..
    i used to be a MT fan.. "ATs are for sissies!". heh heh.
    then i suffered a fractured left leg. that's when i went AT.. my views have softened since.. "ATs are for geriatrics!" heh heh heh.
    errr... fuel efficiency of CVT versus MT ? in my opinion, you'd have to be a pretty bad MT driver, so's the CVT can give you improved mileage.. AT versus CVT fuel efficiency? i don't know.. but for ordinary driving, i believe MT still trumps them all in "fuel management"..
    but that's just me..
    Apr 2014
    In terms of fc, equal lang ang cvt at mt nang mirage. Mas mababa ang rpm nya at high speeds. I own an mt mirage and sometimes kapag trapik, nag wiwish ako na automatic na lang dala ko.
    Either way, at or mt, parahong fuel efficient ang mirage.
    Posted via Tsikot Mobile App
    Sep 2004
    Quote Originally Posted by chronicle View Post
    In cruising speeds where they have equal momentum, this might be true. But in stop-and-go traffic, the lighter M/T returns slightly better fuel consumption figures as the CVT has to haul more weight.
    Jun 2013
    Kmsta po yung FC ng Mirage?Newbie here pls advice po for my wife & kids.From house to school and sometimes going to Tagaytay.Thank you
    Is 2014 mirage meron ECO light, that light's up when your at the r right speed??
    Ok na po yung yung visor n P2300 sa Mirage o mahal?
    Apr 2014
    Normally visors ranges from 1k to 1.5k only.
    Ok b yung Ryan audio n speakers??
    Hi
    Just got my mirage today
    Its a 2014 HB GLS manual, I'll post pic later
    One thing I notice immediately, is the ECO light is not lighting up. Is there a switch that needs to be turned ON? I read the manual nothing is telling how to turn ON the ECO light. Can someone please help....
    Apr 2014
    Eco light only lights up on 2015 models.
    Apr 2014
    My friend owns a 2014 Mirage G4 GLX and I notice that the Eco light lights up regularly.
    Apr 2014
    Hello guys.
    Would you suggest a Mirage G4 GLX or an HB GLX? Which has more legroom, better handling, and better overall quality? I notice kasi na agents are offering bigger discounts and more freebies for the G4.
    Also, what are the improvements in the HB GLS? Why has the price increased drastically from 648T to 673T? The GLX now has alloy wheels and power windows in all four doors, but the price hasn't changed one bit.
    Sep 2004
    Quote Originally Posted by justin_ View Post
    That's because the ECO light was originally available on the G4 only; beginning with the 2015 model year, this will become standard on the hatchback.
    Both the Mirage HB and G4 variants are assembled in Thailand, so there should be no difference in terms of quality. Of course, the G4 has more legroom and cargo space, better rear seats as well as a slightly larger fuel tank. The hatchback is lighter, though.
    As for improvements, the following add-ons were mentioned:
    GLX
    - Silver accent on A/C panel
    - 14" alloy wheels
    - Assist grip x3
    - Cargo room lamp
    - Short antenna
    - Tail pipe finisher
    - ECO assist
    - Alarm
    GLS
    - Center console
    - Assist grip x3
    - Cargo room lamp
    - Short antenna
    - Side mirror with led
    - Fender garnish (replacing the signal light)
    - Front strut bar
    - ECO assist
    Note that some features are dealer options.
    Pano po kalasin yung tail lights ng mirage?
    Dec 2013
    Battery dependent po ba yung keyless ignition start remote natin? Yun po kasing keyless entry system alam ko battery dependent kse may emergency key. thanks po
    May naka pag palit ng bulb ng meter cluster? Peanut bulb lng po b yon it LED?
2013 Mitsubishi Mirage
