Results 5,691 to 5,700 of 5870
- Jun 2015
- 1
- Jul 2014
- 5
July 8th, 2015 01:59 PM #5692
Driver/PasaHERO
- 1,310
July 10th, 2015 03:48 PM #5693just type in your browser Mirage Pilipinas (MPH) | Official Mitsubishi Mirage Club Philippines, register lang kayo then an email will be sent to you for verification. Join the EBs and enjoy the camaraderie
- Jul 2015
- 4
July 25th, 2015 09:47 PM #5694I'm into swift 1.2 at and mirage gls. The issues that i have with swift is that there is no navi system and rear cam and once you installed those two it will void the warranty. Unlike the mirage you can have those without being trouble with the warranty.
Any issues with the Mirage GLS? Please give me an advice which car is better.
July 26th, 2015 08:46 AM #5695
For navigation, use Waze and Mountek. Or buy a Garmin GPS. Reverse sensors will be more effective since sometimes when you backup absentmindedly you can hear a warning beep. As opposed to a reverse camera, if you forget to look, well ...
- Jul 2015
- 28
July 26th, 2015 12:18 PM #5696hi po. ask ko lang po.
comparing mirage and wigo po.. sino po mas lamang in terms of
1. value for money
2. long term maintenance
3. fuel economy
TIA. gusto ko sana marinig from mirage users and later sa mga wigo users naman. hehe
1. value for money
3. fuel economy
- 52,731
July 26th, 2015 12:26 PM #5697I have a wigo at. Mirage uses less fuel than wigo.
Long term maintenance? They're both too young to say...
But for every mirage sold, two wigos drive out of the showroom... because it's a Toyota.
A used car dealer once advised me... Toyotas are easy sells.
July 26th, 2015 12:48 PM #5698
I own a mirage and not a fool about the brand toyota
1.mirage is less expensive compared to the engine technology packed under its hood
Sheer size of the side mirror will tell the difference
2.mine had its impact sensor replaced *16thou kms at no cost because of warranty
mirage utilize only 3 cylinders that means it needs only 3 spark plugs to replace
3.again with just 3 cylinders to fill up with gas, variable valve technology mirage is more fuel efficientLast edited by kisshmet; July 26th, 2015 at 12:52 PM.
- Jul 2015
- 4
July 26th, 2015 03:11 PM #5699
- Jul 2015
- 4
July 26th, 2015 03:17 PM #5700I've heard during curves mirage has a tendency of body roll, I would like to ask if you have any modifications to improve this?
high idle RPM at engine start
