Results 3,901 to 3,910 of 5870
- Oct 2012
- 144
December 30th, 2012 03:40 PM #3901sir ano po mangyayari kapag na pindot mo po ung Start/Stop key pero hinde po natapakan ung brake pedal.....ngyari po sa akin pero ang nag on ung Multi-Information Display, Naglock mga doors pero hinde nag start ung engine ang ginawa ko po is pinindut ko ulit para mamatay po ung MID, Aircon ngyari na po ba sa inyo ngayon ko lang nalimutan na kailangang tapakan ko brake pedal para mag start engine absent minded....
any comments po?
- Oct 2012
- 31
December 30th, 2012 03:44 PM #3902Yes.. if gusto mo in on yung MID or AC just press the start/stop button then press it again to turn off the MID/AC
Sent from my GT-P6200 using Tapatalk 2
- Oct 2012
- 144
December 30th, 2012 04:10 PM #3903
December 30th, 2012 04:57 PM #3904
Just use the start/stop button without using the brake pedal (I'm assuming your car is a CVT based on your previous question). Each press will cycle through the OFF (no light) -> ACC (orange) -> ON (green) without starting the engine. You'll be able to fiddle with the stereo/GPS at ACC as with most cars.
- Oct 2012
- 144
December 30th, 2012 06:03 PM #3905
- Aug 2010
- 1
December 30th, 2012 08:52 PM #3906di ko pa inaaral ung manual..pero naeencounter ko ung multiple beeps pagnilock ko ung car using the pushbutton dun sa pinto tpos pinindot ko lock dun sa 'key' (MOS ba tawag dun?)
- Oct 2012
- 144
December 31st, 2012 04:06 PM #3907
- Dec 2011
- 60
January 1st, 2013 05:49 PM #3909sa tagalng gls! glx tuloy kinuha ko. nakakalungkot lang sa glx halos lahat manual. bkit kaya ang ingay ng ac pag unang on. ganun po ba talaga? saka ang galaw ng manibela kapag nasa 100km na pataas. hay! sana naghintay na lang ako kahit matagal. sana sa di pa nakakuha ng mirage nila, mag gls na lang kayo nakakadismaya ang glx
January 1st, 2013 06:14 PM #3910
Xiaomi E-Car
