Results 3,661 to 3,670 of 5870
December 17th, 2012 01:54 PM #3661
- Dec 2012
- 215
December 17th, 2012 02:06 PM #3662Hi pde mo adjust yung clutch nasa ilalim lang ng makina yung adjuster knob. bandang gitna. may marking naman yung default settings nun kaya madali sya iaadjust.
Also nag pa PMS ka na ba ng 1k KMS? I suggest unahin mo muna yung first PMS kasi malaki ang difference sa hatak. Feel mo muna sya after PMS. Then kung hirap ka parin sa tapak tsaka mo nalang adjust yung clutch
- Dec 2012
- 215
December 17th, 2012 02:10 PM #3663
- Oct 2012
- 49
December 17th, 2012 02:23 PM #3664
December 17th, 2012 02:46 PM #3665
December 17th, 2012 02:54 PM #3666
It's probably the battery. Same thing happened to our 2004 Honda Jazz when it was a month old. Honda replaced it under warranty with a maintenance free Motolite.
Mitsubishi will probably do something similar. The warranty policy says that they'll replace the battery with a local equivalent.
Seems like these batteries are lowest bidder bulk supply pieces of junk.Last edited by Alpha_One; December 17th, 2012 at 02:57 PM.
- Nov 2012
- 13
December 17th, 2012 03:06 PM #3667To sir calix0305,
Ang seatbelt na tinutukoy ko po ay yung para sa passenger na
Nakaupo sa center duon sa likod. Ang seatbelt nun ay kasama
Sa rear seatback (sandalan). Kaya kung kino-collapse o Ipo-fold
ang sandalan, kasama yun seatbelt na tutumba. Eto Ay walang
'seatbelt storage' gaya nang mga nasa gilid.... (manual 2-11)
Sa pagtumba o pagko-collapse ( ng sandalan), ang seatbelt ngayon
ay nakahiga din, kaya, the seatbelt 'pendulum' will lock now the belt
permanently. Ang sandalan ngayon (3/4) ay hindi maibalik kasi, eto
Ay nahahatak nuong seatbelt mismo na naka lagay sa 3/4 rear seat
back (na na-fold)
To ser noob*cars
Nag lock ang seatbelt kase nakatumba ang seatback (folded position). Normally,
Ang seatbelt mechanism should be upright para mag function yung belt smoothly
Unless there is a sudden force or pulling, yung "pendulum" sa loob will automatically
Trigger its locking...
Secodnly, yung seatbelt na tinutukoy ay yun nasa gitna.... Hindi yung nasa gilid (na
Parehong may "seatbelt storage" sa gilid... Yung sa gitna po ay wala...
In this case naman, nakatumba ang sandalan, thus, yung seatbelt "pendulum
Mechanism" is not in its normal position, kaya eto ay automatically nagla-lock...
- Oct 2012
- 49
December 17th, 2012 03:20 PM #3668I DOUBT THE STOCK BATTERY INSTALLED IS HITACHI BASED ON JAPANESE CHARACTER ON WARNING STICKER AND I DOUBT IS NOT TROPICALIZED BECAUSE OF JAPANESE CHARACTER BECAUSE IN JAPAN ARE COLD CLIMATE UNLIKE HERE IN PHIL. IS TROPICALIZED. AT BAKA NAGAKAMALI ANG NAGINSTALL SA PLANTA SA THAILAND INSTEAD TROPICALIZED AY NON- TROPICALIZED DAHIL NAHILO SA BUSY SA ORDER NILA SA MIRAGE AT NAKALUSOT INSPECTOR.
THE STOCK BATTERY IS FOR JAPAN MARKET EXPORT TO JAPAN IF EXPORT TO RP OR THAILAND THE LANGUAGE IS ENGLISH OR THAI. LANGUAGE OR PILIPINO. HINDI KO SINASABI NA ANG HITACHI PRODUCTS ARE UNRELIABLE BAKA SIGURO SA CAR BATTERY LANG SABLAY PERO SA IBANG PRODUCTS KATULAD NG POWER TOOLS AT WATCH BATTERY OK NAMAN AT TV AND ELECTRIC SHAVER. ETC.
December 17th, 2012 03:28 PM #3669
- Oct 2012
- 49
December 17th, 2012 03:36 PM #3670
high idle RPM at engine start
