Results 3,401 to 3,410 of 5870
- Oct 2003
- 176
December 9th, 2012 08:29 PM #3401
December 9th, 2012 10:00 PM #3402
^thats the right thing to do, but since the steering wheel of the mirage is so light its so easy to reach the lock point. turning the steering wheel 3.5 times as compared to other car with less turn can be interpreted as it will take longer but with a responsive power assist its barely significant at all
come to think of it, turning the wheel close to lock point will only make your car turn around faster, how many occasion do we need to turn the car around when we drive? very minimal right
so this issue is very trivial as far as im concerned
- Oct 2012
- 144
December 9th, 2012 11:19 PM #3404
December 10th, 2012 12:13 AM #3405
^3.5 vs 2.5 turns, 3.5 will certainly require more time, assuming both cars steering power assist have the same response time, but a 3.5turn with a more responsive power assist will certainly dispel that notion (3.5 is slower than 2.5)
its a NO BIG DEAL as far as im concerned bcoz mirage power assist in steering is very responsive. it compensates well enough for the extra turn
- Oct 2009
- 155
December 10th, 2012 12:18 AM #3406It depends on how you want to see it. Pero gaya nung nabanggit ni kisshmet sa taas, hindi naman sya issue. And hindi mo sya dapat gawing issue.
Pansin ko lang sir, parang masyado ka paranoid sa mga issues na nababasa mo dito sa thread. If I remember correctly, matagal mo na dapat nakuha yung unit mo. Kung wala ka naman maling napapansin sa drive, wag mo pilit na hanapan ng issue yung unit mo. Kung may mapansin ka na mejo kakaiba sa unit mo, i-raise mo dito para may makuha tayong inputs. Enjoyin mo lang si Mirage mo instead of worrying. Peace.
- Oct 2009
- 155
December 10th, 2012 12:26 AM #3407I agree with you sir na it's no big deal. Matagal na din ako nagddrive and sa totoo lang, di ko binibilang kung ilang turns bago masagad yung manibela. Mas importante sakin malaman yung responsiveness ng steering when using a different car. I never noticed that issue nung nagtest drive ako ng Mirage.
- Jul 2008
- 21
December 10th, 2012 02:20 AM #3408Marikina-Baguio-Marikina route : Total of 621kms travelled using 1 full tank (automatic lang), and isang refuel for 9.27 liters. Best FC is 27.6 based sa mid but when I got home it says 18.9. Question is ilang km/L sya kung manual computation? Tama ba na 14 something km per liter?
December 10th, 2012 06:50 AM #3409
How much fuel was put in with that full tank?
621 km / (x + 9.27 L) = your fuel consumption in km/L
...where x is your full tank amount. :D
- Oct 2012
- 56
high idle RPM at engine start
