Results 2,771 to 2,780 of 5870
November 26th, 2012 09:14 PM #2771
Got the Savanna White GLS CVT last friday. already encountered four problems.
- off from the dealership, I filled the tank full at a station, then the mirage won't start.
- the driver door panel is not properly screwed/clipped. may lagatok pag hinihila.
- the airbag malfunction indicator is lit up from day 1. had it fixed through the dealerships diagnostic software.
- there is a high pitch noise while running with handbrake and the brake not pressed.
the FC as well is not promising as of the moment.
BANNED BANNED BANNED
- Oct 2012
- 236
November 26th, 2012 09:22 PM #2772Meron dapat un kasama EWD depende kng binigay ng SA niyo.
Buti pa kayo nailabas niyo na mga unit niyo. Kami nila calix and the rest sa valle verde hindi pa rin nalalabas and wala pa rn confirmation kng kelan dating. Hay.
November 26th, 2012 09:27 PM #2773
- Aug 2012
- 23
November 26th, 2012 09:27 PM #2774Yep, 35 PSI pag 14" ang gulong. gnawa kong 34 lang kasi 2 lang kami na nasa pasahero. ;)
Nakapag 18.9km/li ako kanina cavite-cavitex-coastal-roxas blvd-manila. pauwi, 15.9 due to traffic.
so far, im not experiencing any problem w/ the car, aside sa mga nabanggit kong puna previously.. Thanks God! pero the busina should really, really go! ang hina at malumanay.hahaha!
so far, im not experiencing any problems w/ d car, aside sa mga nabanggit ko previously.
- Jun 2012
- 4,448
- Jul 2008
- 21
November 26th, 2012 09:53 PM #2776Pag tinodo ang steering either or sa kaliwa...may "tok" kang maririnig. Is this because of the electronic steering? Yung engine nya pag nag tapak sa gas pedal medyo maingay na para kang naka muffler na mahina. Ganyan kaya pag 3 cylinder? Your inputs please. Thanks
November 26th, 2012 09:53 PM #2777
- Oct 2012
- 144
November 26th, 2012 09:57 PM #2778sa mga meron na pong GLS-CVT?
ano po mga problems na naencounter nyo po while driving?
thanks
- Aug 2012
- 23
- Aug 2012
- 23
November 26th, 2012 10:00 PM #2780Im not experiencing any "tok" sound po. Yung engine noise, same as mine, 3 cylinder kasi e.
ang puna ko lang po talaga is the shifting of gears sa M/T. di smooth, parang sumasabit somewhere ang feeling... bakit po kaya ganon, ung mga naka M/T ganeto rin po bang ang experience nyo?
high idle RPM at engine start
