Page 69 of 345 FirstFirst ... 195965666768697071727379119169 ... LastLast
Results 1,361 to 1,380 of 6900
    Oct 2011
    #1361
    I tried to pull open that housing yesterday but unsuccessful. I can't seem to fit my fingers dun sa pinagpapasukan ni Sir Zixx, plus the fact na kabado sa ginagawa hehehe. Iconfirm ko lang Sir Zixx, all i have to do ba sir is to insert my fingers sa konting space between the LCD and the housing tapos pull upwards na?
    #1362
    Quote Originally Posted by TheDudz View Post
    Sir walang upward pull, purely horizontal towards you
    Oct 2011
    #1363
    ah ok Sir. Try ko ulit maya. Thanks! Ask ko na rin pala sir, normal ba na may konting shift shock from neutral to drive or reverse? Pag traffice kasi I shift to N then D parang may konti akong nafefeel na shift shock.
    Apr 2012
    #1364
    thank you zix and prince
    will try to remove my HU cover and check na din if there's a slot for the SD card. baka naman pwede humingi ng files from the Navi SD card para matry kung SD card lang talaga solusyon para magka Navi HU ko hehe
    Feb 2007
    #1365
    Quote Originally Posted by jns888
    Try putting some thin plastic cards sa gaps in between the cover and the dash, ganon usually ginagawa ng technicians while pulling the cover towards you.
    Kahit siguro may card slot(and i guess there is) no assurance pa rin sir na maactivate na GPS map or navigation. But it's worth a try ika nga..
    Sep 2010
    #1366
    Sir nasa casa ako kahapon sa carworld i did ask the lady SA dun yung mga sabi nya wala daw gps yung non vgt pero pwedi daw i load ng software para gumana gps 5k daw.
    Feb 2007
    #1367
    Baka yung OS + Map ang kailangan mai-load to have the GPS activated. 5K is too much siguro. One owner of Advie SE has activated his GPS just by "copying" the data. See 2012 advie thread..
    Jun 2008
    #1368
    Sa mga umakyat ng Baguio this summer, naexperience niyo po ba yung gear e hindi umaakyat o bumababa ng 2 sa uphill climb? Kahit sportronic e ayaw magshift sa bandang Marcos Hway pag direcho paakyat.. Normal ba ito? Pero pag pababa o direcho na yung daan ok na ulit.. Salamat po..
    #1369
    Quote Originally Posted by microvoyager View Post
    Update kita bro, weekend akyat ako diyan. Ako kasi pag uphill automatic sports mode agad ako
    #1370
    Tama ka sir prince, may mga nakapag activate ng gps nila sa advie thread. Two of them just downloaded the files from inav and followed the instruction from the website. sana ganun lang din yung sa mga non vgt para hindi na sila gumastos. But i suggest na before nila buksan, have an sd card extension cable ready para isang bukasan na lang.
    Feb 2007
    #1371
    Quote Originally Posted by zix888
    Naku kailangan pala mag order na uli ako ng marami raming SD extension cables! :-D
    #1372
    Lagyan mo na din ng sd card with downloaded map files, para bolt on :-)
    Apr 2012
    #1373
    Experienced the same thing, sir. Pag continuously pataas yung daan, the engine senses this and high rev yung makina for more power. It stays at 2nd or 3rd gear longer. It goes back to normal driving when on flat roads. This is in our manual. Part of the program of the transmission I think
    #1374
    Quote Originally Posted by NAML View Post
    Same is true if going downhill, and constantly applying brakes, you will feel engine braking. Yan yung adaptive shifting ng monty, depende sa driving style mo, dun siya magbabase
    Apr 2012
    #1375
    Quote Originally Posted by zix888 View Post
    nice suggestion! hehehe i've been planning to see if i can activate GPS in my HU.
    prince - since may reservation na ako sa other item mo, baka pwede din maconsider suggestion ni zix
    Feb 2007
    #1376
    Pwede sir, pakopya ko sayo yung software and map update basta my SD card na kayo, sd extension lang kasi ako meron.
    Feb 2010
    #1377
    went to citimotors alabang yesterday morning, odered a white montero 4x2 GLS-V... got it the same afternoon! heehee! i also got the 3M tint, oem hoodguard, oem window visors, and oem gt-v carbon spoiler installed narin all done yesterday! thumbs up citi!
    Feb 2010
    #1378
    mgs sir, i noticed last night while driving home my new monty na meron 'chime' yung signal indicators, dun sa 2009 4x4 monty namin wala naman chime... ok lang naman meron but if i can disable it, i'll probably do it... hmmm...
    Feb 2010
    #1379
    dun pala sa mga nagtatanong regarding GPS sa non-vgt models..
    if your unit has the GPS antenna (small square box), normally located sa passenger side corner ng dash and widshield, then possible na software lang ang kailangan, if wala then malabo gumana yung GPS nyan kasi it will need the antenna with 'almost direct line-of-sight' to the sky para mabasa location. Hope this helps...
    Apr 2012
    #1380
    For those who have stock GTV, have you experienced a delayed reaction (2-3 seconds lag) upon pressing the accelerator 1/2 to 2/3 of the way while on incline? The car will start to move only upon reaching 1800 or higher rpm. I experienced this twice or thrice while I was in one of those inclines in Baguio. Power was not imediately available. Diamond Motors Valle Verde said nothing is wrong with the vehicle but I have doubts since this was not the case the first time I took the car to Baguio traversing the same streets. BTW, I was using Shell V-power TD at the time.
2012 Montero Sport Owners
