Results 4,831 to 4,840 of 6900
August 15th, 2013 10:03 AM #4831
i just wondering, meron din ba dito nawalan nung takip ng usb/ipod slot nung monty (gls-v) niyo sa ilalim nung dashboard?
bad trip kasi putol na iyong holder thingy niya kaya nawala iyong amin. palagay ko nasipsip nung vacuum eh
August 16th, 2013 04:52 PM #4832
August 17th, 2013 12:19 PM #4833
question naman dun sa may mga paddle shifters. pwede ba mag-sports mode immediately using the paddle shifter kahit nasa D, if yes pano? ang ginagawa ko kasi is ilalagay ko muna sa manual gate yung shift lever (pushing to the left while in D) bago ako mag paddle shift. Also, from sports mode, pwede ko ba ilagay pabalik sa automatic drive mode even when the car is running or full stop dapat?
August 17th, 2013 12:45 PM #4834
same lang siguro sa Lancer sir. While in D mode press mo lang either left or right ng paddle (I use left all the time pero try mo rin right) tapos magmmanual na yun. Everytime na magffull stop ka babalik yun sa D or kung gusto mo na ideactivate ihold mo lang ang press nung right paddle. Nakalagay dun yung off di ba? Yun yun sir.
August 17th, 2013 02:15 PM #4835
August 17th, 2013 03:15 PM #4836
August 17th, 2013 11:26 PM #4837
August 18th, 2013 12:01 AM #4838
mga sir.... 2012 montero GLSV, 30k km, last oil change 20k, no OCC, no EGR BLK, no engine check, no leaks, kapal pa ng brake pads, kapal pa gulong,no shock leaks, as in wala pang pinapalitan na pyesa na under warranty, manila-bicol-manila twice a month, still 20-100km/hr under 10sec(vgt lag), 9.3 to be exact, and servitek since 1k pms, mobil 1 diesel oil, petron turbo(papalit nko unioil kc wala sm advantage ang petron) black smoke bomb(redline) pag dalawang araw under 2k rpm....... mga sir ano po ang critical na papalitan ko na pyesa? di pako nag papapalubricate hangang ngayun..... tnx po!
August 18th, 2013 02:27 AM #4839
sir prince eto na.
Dismantling of PCB to its casing. Woh...mahirap tanggalin, kailangan dahan dahan at tyaga.
Cutting the side of the PCB to fit to enclosure. What I have done is naglagay ako ng jumpe (red wire) dun sa mga naputol na circuit line sa PCB.
Placing and fitting the circuit (btw alarm control circuit pala po eto). Naglagay din ako ng LED lights sa my left corner.
Next stop, yun key naman...
August 18th, 2013 02:33 AM #4840
Nice Job sir! Saludo ako sa effort at tyaga na ginawa nyo...
As long as gumana yung alarm control circuit na yan i'm sure na 100% success ang DIY na eto... anyway hanap parin tayo ng mas convenient na keyfob for DIY next time ;)
BYD Seal 5 DM-i vs. Honda Civic RS: Subcompact-compact sedan Big Test | Top Gear Philippines Top...
(11th Gen) Honda Civic
