Results 4,281 to 4,290 of 6900
Tsikot Member Rank 1
- Jul 2009
- 4,090
January 30th, 2013 12:40 AM #4281
- May 2012
- 23
January 30th, 2013 01:57 AM #4282greetings mga sir malapit na kami mag mag pa 20,000 pms..ask ko lang sana ano po mga dapat i pa check up yong during 20 taw pms
January 30th, 2013 05:47 AM #4283
sir bilog ang holes ng sakin, yung paint bakbak agad sa side ng plate, may mga hibla, parang sticker pag tinangal, rubberized paint/coat ata ang ginamit ng LTO, kala ko na ayos na nila yung tungkol dito, hays... isang screw lang talaga ang pwede sa likod, sisira ang tread ng isa pag pinilit kasi naka tabingi, double tape ko nalang ang isa, wala kc ko pang butas ng plaka, hays....
January 30th, 2013 07:35 AM #4284
You might end up losing your plate or damaging it using the double sided tape which worns out over time. If you don't have a drill, use a rounded file to increase the diameter of the plate holes. A 2mm-3mm adjustment will suffice. Just a friendly suggestion. I was wondering, if both plates doesn't have any misalignment hole issues on the front of a vehicle, bakit sa likod misaligned? Hence, yung butas sa likod ng vehicle ang may issue.
January 30th, 2013 07:51 AM #4285
- Jul 2009
- 4,090
January 30th, 2013 08:07 AM #4286
January 30th, 2013 09:17 AM #4287
good day fellow tsikoteers! anong engine oil ba ang mas ok sa ride natin? mine is a 2012 gls-v. nag-search at nagbasa na ako ng nagbasa. hanggang ngayon nalilito pa rin ako hehe. sa ngayon kasi naka turbo XP ako and nearing 15k na. so plan ko mag-top up muna then pagdating ng 20k gusto ko sana magpalit ng oil. ano ba mas ok? narinig ko na na yung TOP 1 SDO, Petron Rev-X all terrain at Caltex Delo 400. Alin ang ok sa tatlo at pwedeng every 10k ang palit? also, anong difference ng multigrade sa semi-synthetic? and pwede ba OEM filter gamitin ko for the three?
January 30th, 2013 09:18 AM #4288
January 30th, 2013 09:35 AM #4289
January 30th, 2013 09:46 AM #4290
A relative of mine in Canada had his Scion FR-S PPF'd and then had it ceramic coated. He says it's...
Ceramic Coating vs PPF (Paint Protection Film)
