Page 333 of 345 FirstFirst ... 233283323329330331332333334335336337343 ... LastLast
Results 6,641 to 6,660 of 6900
    Dec 2013
    #6641
    Maybe inhibitor switch problem. Bring it to zix or kirsten if you are in Metro Manila they can easily find and fix the problem.
    Quote Originally Posted by plabary1020 View Post
    Hi, I'm now having problem on the tranny of my 2012 Montero Sport GTV (150,000 kms). After driving for more than 50 kms or more and on mainly uphill, the "D" blink (engine check light on) and the transmission is stuck at 3rd gear. Even if I stop and Park, then proceed to drive it's in 3rd gear, which means from stop position.
    I was advised by a mechanic to overhaul the transmission and after doing so the same problem persists. Now what I'm doing if the "D" blink and engine check "On", I stop the engine and restart. It will work properly for a while with engine check still "On", but after few kilometers the "D" will blink again and has to start from engine off.
    After several days the engine check will automatically turn-off and light "On" again when the "D" starts to blink.
    Any thought or experienced that can help on my dilemma? Computer checks had been done and even the input shaft speed sensor had replace.
    Sent from my ASUS_X00DDA using Tapatalk
    Jun 2007
    #6642
    Meron bang service center or hotline ang acdelco in case biglang nag deadset ang battery which is still under warranty? Just like motolite? I bought my acdelco from s&r shaw. Battery is already 19months at 24months ang warranty nya pero nararamdaman ko na mahina na kasi during starting, nagsosound off ang alarm ko. Sorry kung meron ng thread on this, but cant find it.
    Jul 2018
    #6643
    Quote Originally Posted by zix888 View Post
    monty gtv - YouTube
    set the ac to max blower setting and thermostat max setting. you should be hearing this distinct sound when the aux fan engages. (full speed). when its busted, slow motion na yan
    Sir ask ko lang po, kasi pmnta kami ng mcdo southwoods kanina, almost 3kms ride lang ok naman aircon malamig. Tapos nung pagkakain namin, pag start ko ng engine hindi nalamig ung aircon pag binubuksan ko parang hangin lang tsaka tapos biglang may kakaibang tumutunog sa unahan ko. Nawawala pag pinatay ko ung aircon, ano po kayang problema? Samantalang bago po kami pmntang mcdo galing po kaming longdrive from quezon city to binan laguna ok na ok naman po siya non. Btw im using montero sports glsv 2012 a/t. Maraming salamat po.
    Jan 2017
    #6644
    Nangyari na din yan sa kin. Pero karaniwan nangyayari yan sa kin kapag sa ibang gas station ako nagpa-fill up. Try mo na lang na i-reset. Disconnect the battery tapos connect ulit.
    Sent from my RNE-L22 using Tapatalk
    Feb 2007
    #6645
    How about the inhibitor switch? replaced too? Might as well check it.
    #6646
    Could it be a possibility of transmission now overheating? (to the person saying the gear is stuck on third and D is blinking?)
    Has the ATF been checked and replaced with Mitsubishi ATF (not aftermarket)?
    You are in 150T kms, has the fluid and filter replacement been done to the transmission before or ever?
    #6647
    When “D” is blinking, you are in failsafe mode, tranny will be stucked in 3rd gear.
    Maraming possible reasons, low fluid level, not so good fluid condition , clogged atf filter, cooling system(since nakaheat exchange yan sa radiator), input/output shaft sensors.
    1. Have it scanned
    #6648
    1. Have it scanned
    Installing transmission cooler usually solves tranny fluid overheating.
    Feb 2007
    #6649
    *doc zix, how about slipping/sliding AT transmission? [emoji6]
    #6650
    Sa case mo need i-tune down ng konti yung torque , hehe
    Jun 2012
    #6651
    May naka update na senyo ng gps? Hindi ko kasi sure kung alin dito yung para satin. Nag bago na ung interface ng inav.ph.
    Directory listing of http://www.inavcloud.com/portal/Map Updates/Mitsubishi/OEM (Factory Installed)/218Q2
    #6652
    Quote Originally Posted by mar04 View Post
    Bro check mo muna kung ilan memory ng sd card mo, yung latest map update pang 4gb na memory lang, hindi kaya i-accomodate ng 2gb.
    Jan 2017
    #6653
    Tanong ko lang po. Iyong head unit kaya ng montero natin ay pwedeng palitan ng android?
    Apr 2012
    #6654
    Quote Originally Posted by Borj730 View Post
    yes pwede. hindi pa ako nagpapalit but i saw some installs posted ng mga car audio shops
    Jul 2003
    #6655
    Bumalik sa dating interface, yun may relo.
    Be warned like sa mga dating update ni inav lagi sabi ni windows defender may trojan sa updater.exe.
    Better now kaysa katulad ng past 3 updates.
    Sdcleaner first. Kasya sa 2gb card
    Mmv3 ginamit ko. Nasa Pc kaya hindi ko ma doubke check now. Yun wala hyphens or underscore
    May 2012
    #6656
    guys saan banda located ang ecu/computer box ng 2014 montero? thanks
    May 2011
    #6657
    Good pm mga kamonty. Napansin ko lang lately yung pag whistle ng turbo ko minsan intermitten lalot galing sa madiin tapos biglanv release ng accelerator. Is it normal? Dati kasi parang deretcho sipol lang in any condition or baka ngayon ko lang napansin.
    Sent from my SM-G930F using Tapatalk
    Apr 2012
    #6658
    Quote Originally Posted by 3GEMS View Post
    normal sir, pagbitaw sa accelerator saka sisipol yung blow off valve
    May 2011
    #6659
    Yung parang may sinuk minsan bro?
    Resolved my rattling issue in my dash with the use of velcro. Lol.
    Apr 2012
    #6660
    no idea bro sa parang sinisinok, di ko naeksperyens ganyan. minsan kapag nasa steady/slow driving ako at tahimik ang paligid, ibinababa ko bintana then i listen sa sipol ng turbo, so far ok naman.
2012 Montero Sport Owners
