Page 233 of 345 FirstFirst ... 133183223229230231232233234235236237243283333 ... LastLast
Results 4,641 to 4,660 of 6900
    #4641
    Quote Originally Posted by Bengbeng View Post
    Plano ko rin yan eh palagyan ng chin ung akin kaso ala pang budget hehe!
    Maganda yan sir. Lalo na pag kuha ang body color. Good luck.
    Apr 2012
    #4642
    Quote Originally Posted by zix888 View Post
    since magla-layout ka naman ng video cable, from rear to your HU, mas madali kung sa fuse box ka na lang kumuha ng supply for the rear cam.
    sir isang wire lang naman ang ikokonect s hu diba? the yellow one for video feed from after market cam pero bakit wala lumabas ..thanks
    #4643
    Quote Originally Posted by randybm View Post
    bale 2 sir, video jack and the other one is the remote ( a wire that triggers a + signal when shifted to reverse). meron label yan sir
    Apr 2012
    #4644
    ah ok nakita ko may isang wire na nakaabang at the back of hu indicated" REVERSE" beside from the yellow one for camera,,,pero i have only 3 wires to connect from after market cam na nabili ko ,,yellow wire for camera then 4 power supply black for power (+) and the red for ground
    #4645
    yes sir that is right. you can get naman that reverse wire from the fuse box para mas malapit. in short, your + power supply for the cam should also be connected to that labelled wire "reverse". btw inbox full ka sir
    Apr 2012
    #4646
    ok sir thank you very much
    Jun 2012
    #4647
    Need help mga gurus,
    1st: last week dinala ko sa casa ung unit for 10k pms (12k na siya nun) then 2 days after binyahe nila for bicol. then nung monday napansin ng utol ko na hindi na gumagana ung reverse sensor and pundido na ung gitnang ilaw sa 3rd brake lamp.
    2nd: then another inquiry is kaninang pagdating nila nung naghatid ako napansin ko na parang lumalim/humina ung preno e nung pauwi na ko nun from casa eh mas lumakas/bumabaw pa compared from before ko dalhin.
    Question is, pwede ko ba sila habulin para sa 1st na prob ko? eh bago ko naman dalhin e wala namang ganung problems, gumagana ung reverse sensor and hindi pundido ung 1 bulb sa 3rd brake lamp, and then nung kinuha ko ung unit cinonfirm ko sila verbally kung ok na at wala ng prob, umo-o naman sila at pwede ko ba sabihin/ihabol na wala dapat ako babayaran sa sensor at 1 bulb kasi nga wala namang ganun prob ung unit bago ko dalhin? (nakatayan kaya ako? haha. ****)
    sa 2nd naman, d kaya dahil nag bicol sila kaya medyo napudpod/humina ung brakes? btw ung sa receipt nung pms e may brake cleaner dun.
    Hindi kasi ako magaling sa mechanical stuff kaya any help/insight would be very much appreciated para atleast pag balik ko ng casa e may idea na ko at hindi ung gagawing tanga. Thanks in advance mga sirs! Hi sir zix! hehehe.
    Unit is 2012 4x2 gls-v, mag 1 year this mid May.
    Mar 2013
    #4648
    Quote Originally Posted by mar04 View Post
    HI Mar04...
    First of all. Just want to ask if they perform a pre check list before they did the PMS and provide you with the lists?
    2nd,. After the PMS did you try to check everything especially the lights after leaving the Casa.
    --The scenario would be difficult given that the unit was already been used with a long drive (given na di ko masabi if talagang napundi sa casa or not)
    What i would like to emphasized is to have a better proof but Verbal conversation would be difficult to become a proof of evidence.
    I would suggest to talked to your contact in Casa in a Nice way for based on your stories Need to answer first my 1st and 2nd inquiries. This will be your proof of evidence that everything is working.
    Just my two cents of advise.
    Jan 2012
    #4649
    Mga sir, Anong most fuel efficient highway speed ng montero nyo?
    Mar 2012
    #4650
    Quote Originally Posted by hersoniii View Post
    sabi sa thread dito is 80kph, steady. but it seems mas mabilis mag pickup yung km/l FC sa head unit pag around 60-70.. not sure on its accuracy though
    May 2012
    #4651
    Sa akin between 90 and 100 kph accdg to the HU.
    May 2013
    #4652
    Mga guys ilalabas ko ung montero glsv ko tomrw ano bang need kong i check sa unit bago lang po kasi ako thank you
    Sep 2011
    #4653
    fastest speed you can achieve in the highest possible gear while on the lowest possible RPM for that gear ;) In my case that would be 50 kph ( On 5th gear with the RPM just above 1K). Kaso Minimum in NLEX is 60 kph kaya sa provincial highway lng sya applicable
    Jul 2012
    #4654
    Hindi pala madetect ng alarm ang pagbaklas ng front fog lights ang side claddings. Yesterday at around 620am ng tinanggal ko ang car cover wala na yong 2 fog lights sa harap at driver side door claddings. Hindi lang sa metro nangyayari uso na rin sa Gentri, Cavite. Nakapark sa tapat ng bahay a feet plus from the wall enough na mabuksan ang pintuan at makapasok ng patagilid.
    Mar 2012
    #4655
    Quote Originally Posted by mangkas1178 View Post
    san sa gentry yan sir? sorry to hear the news. grabe na talaga ngayon
    Feb 2013
    #4656
    Buti sir yan lang ang nakuha, try nyo ipaadjust sensitivity ng sensor nyo
    Jul 2012
    #4657
    Quote Originally Posted by jasperjugan View Post
    Sa Gen. Trias po, bale may tig tatatlo na screw yong fog lights lima ang narecover ko sa baba na sa tanya ko dalawang screw thread lang ang kumakapit kaya madaling hatakin pa labas ang fog light assy. Ang cladding naman parang sealant lang ang pangkapit sa pintuan. Sanay na sa baklasan ng monty accessories ang gumawa kahit aso d umingay. Try ko sa casa kong makapag adjust ng alarm sensitivity.
    Jul 2012
    #4658
    ACM, Navarro pala sa amin.
    Apr 2012
    #4659
    Sorry to hear that sir. Victim din ako ng mga yan. Nawala 2 fog lights ko recently. 25k damage ng fog lights kasama cover. Mine was stolen in front of my house as well sa better living paranaque
    Sent from my GT-N7100 using Tapatalk 2
    May 2013
    #4660
    Sir im a monty gls v 2013 owner/newbie ... May question lang po ako regarding sa equalizer ng HU, napansin ko lang kasi na kahit i set ko sya na naka ON ung loud nya na rereset sya lagi pag nag switch off ako ng engine, may dapat po b ko gawin para ma program sya?
2012 Montero Sport Owners
