Page 154 of 251 FirstFirst ... 54104144150151152153154155156157158164204 ... LastLast
Results 3,061 to 3,080 of 5006
    #3061
    Feb 2007
    #3062
    Thanks again sir zix.
    Yung SD card na gamit nyo is different sa SD na nakalagay sa unit? I assume na yung na download lang na file yung laman ng SD. ;)
    May 2011
    #3063
    I agree! I love the way the screen splits into two showing junction view before turning.
    Quote Originally Posted by zix888 View Post
    Best update so far from inav
    #3064
    If you have extra sd card, use it, but if not, just use the navi sd, no need to erAse the navi files, just drag/drop the sw_update file, then after the update, turn off, get the sd card, change the sw.. File by adding extra character, or just simply erase the sw.. File. Just leave the navi files as they are, no need to erase/rewrite.
    Feb 2007
    #3065
    Noted sir, thanks.
    Hope i will still have a chance to update before my roadtrip..
    Apr 2011
    #3066
    Quote Originally Posted by jasapix View Post
    sharing...
    sir jasapix, if you would'nt mind magkano kaya nag magpakabit ng ganito? TIA!
    Jun 2009
    #3067
    Quote Originally Posted by boogie67 View Post
    pm sent sir boogie67
    Apr 2011
    #3068
    salamat sir Zix..
    Sir sa carworld marilao ko nakita yung sensors
    Jul 2004
    #3069
    Quote Originally Posted by jayteecie View Post
    yep ang galing nga nitong split screen display function especially when approaching overpasses
    pati mga road/directional signs nakuha
    Jan 2011
    #3070
    Sir Zix same lang po kaya pag update sa pajero ng navigation system. yung sd card namin nasa harap yun din po ba kailangan tangalin o may sd card pa din yung HU sa loob and kailangan tangalin front panels?
    #3071
    Quote Originally Posted by davesy View Post
    While system is off, get the sd card, explore ninyo sa pc, makita natin what are the files inside. From there malaman natin if yan yung sa navi
    Apr 2011
    #3072
    Thanks for your comment sir prez and spotdog. I already send back my MS to Casa. Sa may Unioil Multinational Pque ako nagpa full tank before I experience yung problem. They told me they will change the SCV and fuel filter. May idea po ba kayo sa SCV?
    i agree with this
    if i am not mistaken, someone over at MSCP posted a picture of his EGR using seaoil and it was clean. a picture of a clogged EGR was also posted and grabe grabe ang bara ng deposits
    that convinced me to use seaoil also
    May 2012
    #3073
    Hi all, I'm a newbie here, ask ko lang po if anyone has experienced a humming noise at speed of 80 until 90 kph? Tapos mawawala ang ingay pag lumampas na sa 90kph. Parang dinig ko galing sa differential. THe noise is beginning to irritate me, my 20k maintenance is due next week and I will have it inspected, baka meron ng nagkaroon ng ganitong experience paki share po what is causing this.
    Jan 2011
    #3074
    Sir the folders inside the SD are genietek, navigation, navigator and lost.dir if I remember it right.
    #3075
    yan nga sir yung sa navi. go ahead and download this http://inav.ph/download/PAJERO20.EXE
    enjoy the update. pero check ninyo muna baka updated pa naman yung map ninyo as of now
    Jan 2011
    #3076
    my CPU keeps on telling me to format the sd before I can use it, do you have any idea kung anong format gamit ng AVT? I'm downloading the update thank you sir for the link.
    Apr 2012
    #3077
    Sir Ongie28 and Jepoy_megs, nasa akin na epektos. Antay ko nalang SD cable.
    Sir prince 777, new here in the forum. Just want to inquire if you have extra key fobs and SD card extension in your inventory. I want to get one. Would appreciate if you could PM the price. Also, will the key fobs work on a 2012 GTV. Key fobs looks cool. TIA
    #3078
    Quote Originally Posted by dhinster View Post
    hi sir dhinster. i am a bit concerned. coz i am using unioil also pero doon ako sa may katabi ng wilcon along sucat nagpapakarga. i thought ok ang unioil dahil euro 4 sila or depende sa station? how long have you been using unioil if i may ask?
    Jan 2008
    #3079
    brader, pang update lang ba ito?? kasi may adventure ako eh na may AVT din na HU kaso wala pa SD card na pang map.. eh mahal yung SD card sa winterpine nasa 5,500 petot.. gagana kaya yan
    #3080
    I am not sure sir kung sd card lang kulang niyan to make the navigation work. Try ninyo sir lagyan ng files yung sd ninyo. Pero tingin ko diyan OS modification kelangan ninyo before it will work. Tsaka any sd card will work, kaya sobra mahal naman kung 5500 just for that
2011 Mitsubishi Montero Sport [continued]
