Page 155 of 251 FirstFirst ... 55105145151152153154155156157158159165205 ... LastLast
Results 3,081 to 3,100 of 5006
    Jan 2011
    #3081
    The glx HU has no RV meter, reason why there is no system information showing at the same time hindi din sya pwede lagyan ng steering remote. Pero meron na sya TV icon kaya pwede ng mag install ng AVT 399 na TV tuner...yun GPS, you cannot be able to activate it by just downloading the map update. yun HU calls for the GPS software na nasa mahal na SD card, even copying it to another SD will not work...
    Jan 2008
    #3082
    Quote Originally Posted by zix888 View Post
    I am not sure sir kung sd card lang kulang niyan to make the navigation work. Try ninyo sir lagyan ng files yung sd ninyo. Pero tingin ko diyan OS modification kelangan ninyo before it will work. Tsaka any sd card will work, kaya sobra mahal naman kung 5500 just for that
    yun ang sabi sa winterpine eh.. kaya nga medyo nag aalangan naman ako para sa 5,500 lang na SD card...sa price na yan makakabili na ako ng garmin... kaya lang gusto magamit yung GPS capability nung headunit.. grabe naman kasi yung taga sa presyo...
    na try nyo na po ba mag clone ng SD card?? paano ba yan OS modification thru sd card din?? kung ok lang pa share naman hehehe
    akala ko nga pwde din music dun sa sd card slot, pero mukhang pang GPS lang talaga
    Oct 2011
    #3083
    Doon sa car shop sa tabi ng winterpine baka kaya nilang gawan ng paraan yan SD card.
    #3084
    Navi and OS modifications/update lang ang functions nung sd slot. And yup pwede gumamit ng ibang sd card, actually what i am using now is just a clone. What you need is OS ng navi, which is a file na gagamitin para maactivate yung navi mo, then after that , any sd card na may map files will work. Ang mahal nun para sa 5500, kaya i suggest diskartehan mo yung technician, na after finishing the os update, huwag i-erase yung file na ginamit, ganun kasi ginagawa nila sa pag fix ng usb, os update tapos binubura nila yung file na pang update. tapos hanap ka ng kashare na naka same monty variant, kung 5 kayo, a little over 1k na lang bayad each. Then i-share ninyo sa mga tsikoteers, dami ninyo pasasayahin.
    Jun 2008
    #3085
    [IMG]cid:33E8029D-06DE-49DA-B37C-90304AA20280/photo.JPG[/IMG][IMG]cid:28FC078D-87B6-4DA2-BA41-942BC63C8970/photo.JPG[/IMG][IMG]cid:80B8D9A4-6A93-4EE7-B09A-127C349C7BC4/photo.JPG[/IMG]
    May 2012
    #3086
    Good day everyone, I'd like to ask, for those of you with the Mitsubishi Multimedia System, are you experiencing a bug with the shuffle option in playing back music from a USB? Playing back the music is fine but the shuffle option doesn't seem to work.
    Apr 2012
    #3087
    Good idea sir zix ayos to! thanks sir! san pala pwede buy sd card reader ksi sbi nila wala daw sd card reader yun HU ng non-vgt??
    #3088
    Quote Originally Posted by fitdynamite View Post
    Naku yun lang sir, kung wala sd card slot yung monitor, eh malamang palit monitor w/ sd slot yan. Tama, 5k nga yan, may nag aalok sakin niyan before, tech guy sa isang casa. Dapat macheck kung may lagayan ng sd card
    May 2011
    #3089
    Sir Zix, if you don't mind, how did you clone your SD card please? Thanks
    #3090
    Quote Originally Posted by jayteecie View Post
    I just copied all the files from the oem navi sd card, drag/drop.
    May 2011
    #3091
    Thanks Sir Zix. I remember doing this before but didn't work. Is it imperative to do the Software update for this to work?
    Apr 2012
    #3092
    Got your PM sir prince 777. Will just wait for your update. Thanks
    Fellows, if there is anyone who has an extra SD card extension, kindly PM me. I'm interested in getting one. Thanks
    Apr 2011
    #3093
    Hi Matty,
    I just used Unioil once before my MS problem starts. As many tsikoteers here confirm na okay ang Unioil so I decided to try. Maybe it depends on station. I got my MS yesterday and after pull down of fuel tank and changing the SCV plus fuel filter, malakas pa rin usok nya. Saan or ano pa po kaya ang pwede ko pa check?
    tia.!
    Quote Originally Posted by matty View Post
    hi sir dhinster. i am a bit concerned. coz i am using unioil also pero doon ako sa may katabi ng wilcon along sucat nagpapakarga. i thought ok ang unioil dahil euro 4 sila or depende sa station? how long have you been using unioil if i may ask?
    #3094
    Quote Originally Posted by dhinster View Post
    Hi Matty,
    tia.!
    ganun ba sir. baka nga nagkataon lang na pagkarga mo sa unioil lumabas na yung pagka-usok or madumi lang dun sa station na yun. nakadalawang fulltank na ako sa may unioil sa tabi ng wilcon and so far ok pa naman. with regards to your problem, hindi pa ako naka-experience nyan and i hope i don't. i cannot share anything about it. but there are a lot of experts here who can help you out. and some have encountered same problem already and probably they can inform you what else to check. i hope your problem will be resolved soon.
    Jan 2011
    #3095
    Hi Matty,
    tia.!
    Im no expert but here is my opinion. Since you got your monty only yesterday, its possible that the smoke is just the remaining carbon deposits within your exhaust system which accumulated when your car had a problem. Hataw nyo sir by flooring it 0-100 km/hr mga 2 times lang. After that it should clear up. There should be no smoke on your 3rd sprint. If the problem persist, ask the casa regarding EGR cleaning with reprogramming.
    #3096
    Even before the os update i have used a back up sd card . Using windows, I copied an old map, that was the 1.6a version(copy paste). Then copy a new map version exe file , then run the exe file.
    May 2011
    #3097
    Thanks! Will try this again.
    Apr 2009
    #3098
    Doc marami pong salamat sa pictures.. meron pa pala talaga length to spare.
    This is really a great help.
    Map Update 2.1 here: Genuine OEM
    Meron na pala map version 2.1!
    Kapapa-update lang nung May2... Version 2.0 pa rin nilagay nung tech...?
    Nu ba yan~
    Apr 2009
    #3099
    I agree! I love the way the screen splits into two showing junction view before turning.
    Medyo nakakairita nga lang sa gabi, biglang liwanag when the split screen appears on the display.
    Sep 2011
    #3100
    [/QUOTE]
    Nice share zix, but just want to ask whether my OS is older than this update since when I check my versions they showed the ff:
    APP_V 3.1.85_0613_110425
    MCU_V 0.1.30_0613_110223
    MPEG_V 3.06.38_0613_101215
    ang di ko lng nakita sa pix mo ay yung WOS_V 3.25.0_0613_110218
    This will be my first OS update, got my unit last september 2011, if mas recent yung file will proceed with the update.
    Many thanks!
2011 Mitsubishi Montero Sport [continued]
