Results 4,641 to 4,650 of 5002
- Aug 2013
- 11
August 5th, 2014 08:35 AM #4641strada onwers, naexperience nyo nb yun volume ng stereo ay nag malfunction? ano ang ginawa ninyo para maayos?
August 5th, 2014 09:48 AM #4642
- Aug 2013
- 11
August 5th, 2014 11:21 AM #4643thanks, pro misan malala pa ang yari sa stereo ko, kusa naglilipat ang SRC, naiinis nga ako kc nakikinig ako ng music through USB tapos lilipat sa radio tapos papasok ng navi. balak ko sana magclaim ng replacement ng stereo under warranty p naman ang unit ko. o baka repair lang ang option nila?
- Aug 2013
- 11
August 5th, 2014 11:22 AM #4644thanks, pro misan malala pa ang yari sa stereo ko, kusa naglilipat ang SRC, naiinis nga ako kc nakikinig ako ng music through USB tapos lilipat sa radio tapos papasok ng navi. balak ko sana magclaim ng replacement ng stereo under warranty p naman ang unit ko. o baka repair lang ang option nila?
- Jun 2013
- 179
August 5th, 2014 07:33 PM #4646
August 6th, 2014 02:36 AM #4647
wala pang lift, nag iipon pa But I'm using 32" Cooper STT mud tires on stock rims ngayun.
I'm assuming your asking about the 2" body lift and not the suspension lift? Sa body lift almost walang pinagkaiba yung ride comfort mo nyan provided na stock parin yung suspensions mo. Sa tires nalang mgkakatalo yan (ATorMT) dami option. Wala lang akong pera kaya limited ang option ko hehehehe.
August 6th, 2014 10:03 AM #4648
guys yun mga fluids ba let's say coolant, brake fluid, power steering fluid etc...
pag dating ng 40k km to 50k km need na po ba talaga palitan as in drain then lagay ulit?
or pedeng top up lang?
- 62
August 7th, 2014 10:03 AM #4649
- 81
August 7th, 2014 08:35 PM #4650Mga Sirs, saan po makakabili ng cabin filter? planning to install one. after 6 years humina na ac ng rig ko kaya ipapacheck ko sa labas sabay install na ng cabin filter and magkano po?Thanks!
high idle RPM at engine start
