Results 4,501 to 4,510 of 5002
June 4th, 2014 08:32 AM #4501
as a matter of fact its all up to the owner if he wants to risk blowing his engine out by driving his/her car above the break in spectrum. But if you want to be safe then it is common sense to follow what the manufacturer is telling. Makabago man o maka luma if you care for your engine I don/t think it would be wise na ihataw mo yung makina mo. That's why it is called "break-in period". Some say that hindi daw magiging maganda yung top speed pag binibaby mo sa break in. Well, last time I tested, I got 190km/h on miy rig, all stock. But if you dont believe in the the correct breaking in of the engine, then by all means do what you like. Its your car and money
June 7th, 2014 09:18 AM #4502
i've got a set of new shoes for my strada black rhino glamis 18x9 with +12 offset, and im planning to pair it with federal couragia S/U 285/60R18, my question is.. may rubbing po ba ito sa wheel well ng strada? any inputs mga bros..
June 7th, 2014 11:29 AM #4503
- Jun 2014
- 1
June 9th, 2014 09:35 AM #4506
- Jun 2013
- 179
June 9th, 2014 02:01 PM #4507Mga Sir tanong lang,
Ano po kaya tire brand pa ang similar sa Nitto Trail Grappler? Mahal kasi isa ng Nitto Trail 26K+ ang isa.
Thanks.
June 10th, 2014 01:09 PM #4508
help!!!... napakaingay pa rin ng leaf spring ng aming strada... ano po ba problema nito? baka may naka experience nito sa inyo... thanks...
Posted via Tsikot Mobile App
June 10th, 2014 08:09 PM #4509
- Mar 2014
- 30
June 11th, 2014 07:20 AM #4510Help mga sir..my clunking sound ung strada namen when shifting sa third gear galing sa second gear..para bakal n nahuhulog.other than that nmn e smooth shifting cia..basta from second gear papuntang third tutunog n cia...anu po kaya ito..at ung steering wheel namen my tok pag liliko ng mabagal..haizzzzz help!!!
high idle RPM at engine start
