Page 440 of 500 FirstFirst ... 340390430436437438439440441442443444450490 ... LastLast
Results 4,391 to 4,400 of 5000
    Dec 2011
    #4391
    Quote Originally Posted by ezrydre View Post
    when you say nawawala as in wala talaga o bawas lang? tsaka tanghaling tapat ba? kapag umaga, hapon o gabi ganun din ba?
    Aux fan will definitely help cool the cabin more during traffic, but it depende rin talaga sa problem mo.
    parang nag shutoff yung aircon walang lamig. kapag na stuck sa traffic naka idle. Kapag ni rev ko mga 2k rpm bumabalik lamig.
    Dec 2011
    #4392
    Quote Originally Posted by D3nb3r View Post
    By "stop" you mean naka idle ang engine mo? Pag naka idle po ba yung engine ay na notice nyo ba ang rpm an tumataas at bumababa? Better bring you rig to a certified aircon specialist. Dami din mga causes yan but I don't think adding an auxiliary fan will solve the problem that you have. Dahil kahit mag install ka nang fan and marumi yung cooler condenser hindi pa rin mag improve yung aircon mo. Ma notice mo rin pag medyo kulang na ang freon is medyo mag mga frosting kang makikita sa piping nang aircon. If medyo DIY ka, masisilip mo rin yung pipings nang evaporator just below the steering, just above the accelerator pedal medyo tatangalin mo lang yung mga panels na naka screw and grommet clips.
    Sir stop ko means naka idle. nawawala lamig kapag matagal naka idle ng tanghali. steady lang naman yung idling ko. kapag ni rev ko lalamig nanaman, Hindi ko kung kapag ni rev ko pa lumalakas hangin kaya lalamig ulit.
    Before ako bili ng auxiliary fan baka hindi rin ma solve problem. sa Gabi walang problema malamig pa rin aircon. kapag maiinit lang panahon talaga.
    Apr 2010
    #4393
    check mo muna sir AC belt, baka luwag lang. Nothing to lose ka nman sa aux fan. even if nde yon ang problem mo, malaking tulong yon. for me, i just go the cheaper option, 500 pesos aux fan sa mga autoshop. kaya lang kelangan mo i tweak at gawan ng bracket.
    Posted via Tsikot Mobile App
    Mar 2012
    #4394
    Quote Originally Posted by BoyAPV View Post
    So bumubuga pa rin yung fan blower kahit na when you said it stopped. Have you check na yung setting nang thermostat or the bulb of the thermostat? pwede din na marumi na masyado yung evaporator mo. Gaano na po ka tagal since last service/cleaning nang aircon nyo?
    Buying an auxiliary fan is ok since makakadagdag nang cooling effect yan sa freon pag daan sa condenser but if nasa ayos ang system nang aircon mo, you wont be needing that. Di hamak na mas malaki yung cabin area na pinapalamig sa Montero compare sa strada kaya it needs an auxiliary fan. But still, walang masama in buying/installing the aux. fan if may extra cash ka pa.
    May 2010
    #4395
    Madumi na aircon filter nyo boss
    Dec 2011
    #4396
    yup bumubuga pa rin ng hangin yung blower. wala lang lamig. Settings naka 3/4 naman. Hindi ko pa napa aircon cleaning. Siguro nga pa check ko muna baka marumi.
    Malamig naman kasi pag gabi or hindi matindi sikat ng araw at hindi na stuck sa traffic.
    Thanks
    #4397
    Mga sir Tanong ko lang if may na experience na kayong squeking sound sa manibela pag lumiliko. Less than 2k palang strada ni misis may gnun na kse
    Jan 2014
    #4398
    hi! new owner here. strada 2014 glx-v automatic. ask ko lang po tungkol sa auto lock. kasi pag nilock ko nag bliblink yung blue light so tingin ko di sya naka valet mode (correct me if im wrong). trinatry ko kasi na iclose yung door tapos hintayin na maglock ng kusa kaso di sya naglolock. ganun po ba talaga or may kelangan pa akong gawin? tapos yung sa dash, possible ba na makita ko yung fc sa monitor? may kelangan pang gawin or idagdag?thanks!
    #4399
    Thanks
    Same sa nangyayari sa strada ko ngayon. Kapag nakaidle ng matagal nawawala ang lamig. Linisin ko aircon filter ko tonight tapos observe ko ulit bukas. 7 years na strada ko without any aircon cleaning.
    #4400
    pag na lift tayo iiba talaga ang geometry nang suspension natin. dapat ingatan natin yung cv joint at yung sa mga naka manual tranny naman delikado din yung center bearing pag nag lift above 2". IMO, pag di ka rin lang naman pumupunta sa mga heavy trailing and ground clearance lang ang habol, then lift block and spacer ay oks na tapos samahan mo pa nang 32" tires so mga more or less 5" na itataas nang ground clearance nun. But if you have deep pocket and budget is not an issue then full aftermarket suspension kit na lang pa install mo
    some info from aussie triton forums:
    Attachment 20901
    Attachment 20902
    sir can you recommend a shop for this? i want to lift my strada 2inches
2010 Mitsubishi Strada [continued 2]
