Results 3,791 to 3,800 of 5002
- Aug 2009
- 181
August 30th, 2013 02:16 PM #3791baka mapagtripan na nakawin sir tas hindi mo namamalayan eh puro tubig na pala ilalim ng bedliner mo.
dyan mo pala nilagay yung black rhino decal mo sir, ayos.. sakin sa magkabilang gilid ng bed pero hindi masyadong halata kasi black yung kinuha ko and mica grey unit ko..
- Jun 2013
- 179
August 30th, 2013 02:28 PM #3792
August 30th, 2013 03:24 PM #3793
If I were you ,I will retain the Roll bar, than install spoiler, your roll bar top shade will act as a shade to your rear mirror,same as the spoiler, even minimal the roll bar will have safety purpose, but anyway follow your heart if spoiler will give glow to your heart he he he he..
- Jun 2013
- 179
August 30th, 2013 03:42 PM #3794thanks Sir, medyo may problem lang talaga Sir ako, madali kasi ako magsawa sa nakikita ko hehe. Temporary lang naman yun plano ko na pag-alis ng roll bar para maiba ang look lang, then siguro pag gusto ko na uli ang roll bar ibabalik ko ulit. Yun plan ko naman sa spoiler eh pang palit lang din sa looks, pero kung yun paglalagay ng spoiler eh permanent o yun hindi na pwede tanggalin eh baka hindi ko na lang ipalagay.
August 30th, 2013 04:44 PM #3795
August 30th, 2013 07:58 PM #3796
if mag palagay kayo nang spoiler sir, i hope you dont expect anything from it to improve the performance of you car. dahil walang silbi yung spoiler na yun for a pick up truck other than aesthetic lang. but it still your rig, and what ever makes you happy, then go for it. if you want those kinds of mods, you can check out thailand triton clubs. hindi lang mga monster strada dun but also mga lowered and drag spec strada.
- Jun 2013
- 179
August 30th, 2013 08:43 PM #3797
August 30th, 2013 08:56 PM #3798
yung butas sir, you can put some sheets w/ adhesive on it pero pangit lang tingnan. try looking for blanking rubber grommets that has the same size sa butas sa ng bed liner mo. mas oem look pa tingnan if mka kita ka nang sames size. btw, some rubber grommets are designed para butasan and to pass somthing in between, in your case wag mo na butasan.
- Jun 2013
- 179
August 30th, 2013 09:46 PM #3799
August 30th, 2013 10:06 PM #3800
its up to you sir. kung iiwanan yung tornilyo dun but if takot ka may pumasok na tubig dun sa butas. lagyan mo na nalang nang rubber gasket w/ washer yung tornilyo and tighten up the nut to prevent the water from going in. down side is, you have a threaded bolt sticking out na maka cause nang mga sabit and also the bolt n nut is expose to weather that can cause rust. unless gumamit ka nang stainless steel bolts and nuts. kung may mga left over ka na aerosol paint pwede mo ring gamitn yun to cover the bolts para di kalawangin.
Xiaomi E-Car
