Results 3,651 to 3,660 of 5002
August 7th, 2013 10:41 AM #3653
Good day. kinsa member strada club cebu dre? thanks(sino member strada club cebu dito)
- Jun 2013
- 37
August 8th, 2013 10:12 AM #3655
August 9th, 2013 06:24 AM #3656
Why ka pa pi diy when there are ac filters ranging from 450 to 1700pesos in the market. The cheapest are disposble while the most expensive ones are washable.
August 9th, 2013 08:30 AM #3657
August 9th, 2013 09:05 AM #3658
Sir,
Mabilis lang, if you take out the glove compartment, makikita nyo na po yung slot, but nakasara pi yun so you will a blade to slice the enclosure where the fiter will just slip in. If makita ninyo, mabilis mavisualize.
August 9th, 2013 09:21 AM #3659
after taking out the glove compartment we still have to take out the black plastic cover w/ 5-6 screws and 1 plastic pin and diconnect the wire connectors for the usb/airbag before we can access the cabin filter enclosure. then we have to cut the plastic cover in the enclosure os we can insert the filter.
- Aug 2009
- 181
August 9th, 2013 06:51 PM #3660sir questions: anong offset nyan? kasya kaya 275/55/20 saffiro max trac a/t positive 12 offset without spacer or lift? baka yan nalang kasi ipakabit kong goma kung meron si wheel gallery kasi me dumating na syang molave na +offset ayaw ko kasi sa -12offset nya masyadong labas sa fender mukha tuloy pandak and hindi ko na rin mahintay yung rockwell nya eh not sure pa daw kung me darating ng sept and oct. sa iba naman ang mahal 55k mags palang and bibira meron.
high idle RPM at engine start
