Results 3,201 to 3,210 of 5002
April 12th, 2013 08:46 PM #3201
April 13th, 2013 05:12 AM #3202
need some background on aux fan sa strada. marami na ako nabasa na pag nag lagay ng fan lalamig ang aircon ng ride natin. my question is, yung cooler po ba na tinututukan ng aux fan is yun din po ba ang cooler ng freon from the compressor going to the evaporator? gusto ko rin mgpa install nang aux fan but i want to know what is/are the purpose and use of this mods. thanks.
April 13th, 2013 09:40 AM #3203
Mine is 2010 model walang pang ginalaw sa aircon and until now malamig pa rin....
April 13th, 2013 10:18 AM #3204
I plan to do this also, install a condenser aux fan. Malamig naman ung aircon, ang problem lang ay hindi sha consistent. Iba shempre ang lamig pag unaandar at naka stop. Mejo okay na kung 5.5k ung oem monty aux fan, direct bolt on naman yun, pero mas okay kung meron pang mas mura na pwedeng ikabit.
April 15th, 2013 05:20 PM #3205
Thanks guys sa mga input re- aircon, inspite the age of my strada hindi pa rin patatalo sa Trailblazer, still mighty, in fact my wife loves more to drive the strada than the Trailblazer, take care of your strada & she will look after you in time of needs like an obedient dog.
- Oct 2009
- 1
April 21st, 2013 06:55 PM #3206Planning to buy a Strada this May- any recommended casa/dealer in manila? I backread and noted the troublesome casa's but couldn't find anyone recommending a casa na maganda ang experience nya.
- Apr 2010
- 131
April 22nd, 2013 07:09 PM #3207*icicle
Usually wala namang masyado issue sa casa when buying, the concern is during PMS. Pede ka naman lumipat ng casa sa PMS mo.. Pede kahit di sa casa kung san mo binili.
Though there are also some that needs to be avoided. Based on my experience, avoid Paco and based on reading avoid Manila Bay.
Try do more readings. Also, you can surely get a better deal if you loan thru bank than direct to casa.
hth
- 217
April 22nd, 2013 10:47 PM #3208may mga problema minsan kung bibili ka sa sales na kausap, dami ko nakausap na ahente minsan iniisip lang nila kikitain nila hehe puro reservation etc ang maririnig, kelan mag dadown pero di tinatanong ano gusto ng client ehehe.
ako sa kalookan bumili medyo may ahente na narefer sa akin ok naman, inantay pa ako hangang 7pm makita ko lang yung unit
yung sa valle verde dati nagpapaantay ako ng 5:30 ang sagot sa akin uwian na daw nila.
after a week nag fofollow up kelan daw ako mag down, nag sabi ako kumuha na ako sa kalookan, tapos panay follow up sya di ko na pinansin hehehe
- Nov 2012
- 95
April 23rd, 2013 08:40 AM #3209
April 24th, 2013 02:11 PM #3210
I brought my 4yr old strada sa car aircon specialist, the reason kaya pala hindi lumalamig pag mainit ang sikat ng araw is due to leak sa cooling coil, same time kasama na ang linis sa other ancillary parts(evaporator, condenser, etc) they found out na wala palang micro filter ang aircon system ko, Guys i-check ninyo kong mayroon micro filter ang aircon ninyo, if none better palagyan ninyo it will help in maintenance.
high idle RPM at engine start
