Results 1,511 to 1,520 of 5002
- Mar 2011
- 7
May 6th, 2011 08:04 PM #1511Yung mga nagkabit po ng aluminum roller lids, hindi po ba makalampag ang aluminum?
I am looking at 2 models, yung sa carryboy po at yung sa camper shells Pace Edwards. Mas maganda po ata sa strada yung sa camper shells.
And ang purpose ko po pala is to protect my luggage from the rain. Hindi po ba talaga pumapasok ang tubig?
Thanks!
May 6th, 2011 10:30 PM #1513
May 7th, 2011 07:16 AM #1514
Same problem with the aircon system....35 k na strada ko and the SA advised na sa 40 k na galawin.....kasi sched daw ng ac cleaning......... Sabi nya dalawa daw ung ac filter...isa sa may likod ng glove box at sa likod ng evaporator...... To think of na 15 k pa ako nag complain...... Sa squeaky leaf spring....may kinabit ung casa in between springs at nawala ung tunog, tumas din ng 16mm ung rear ko after, sa 15 k din nag simula un....advise ng iba light oil or grease.... Pero dapat daily..............sa horn..... Was my second modification....3 days after i got my unit.... (one day after i brought it home)
May 7th, 2011 09:56 AM #1515
parekoy iliniaw mo sa SA mo yung tungkol sa sinasabi nila na filter ng A/C system ng strada... kasi as far as i know walang filters ang mga strada sa a/c system, unless biglang naisipan nila lagyan yung mga vgt models na.
regarding sa cleaning naman, as much as possible wag dapat pagalaw yung a/c system kasi once binunot yung evaporator mo, sunod sunod na yan, may mga kakalampag, iingit, sisingaw, etc....
my truck is already close to 5 years old and have never had the evaporator pulled down.
only thing i changed on mine was i installed a diy a/c filter element
May 7th, 2011 04:03 PM #1516
May 7th, 2011 06:04 PM #1517
Hi Sir Arvin Cristi,
Its my shortcoming to mentioned the SCV na nililinis, what I mean is EGR, possible bang in one year time to change SCV valves dalawang beses or more. Im not 100 percent sold sa fuel problem, dahil petron & shell lang ang pina-patronize ko, I hope im wrong na the SCV problem is caused solely by dirty fuel, it can be beyond that. If the Casa will suggest to change again the SCV, then I will try the other brand (Bostich) kung pwede.
Rgds.,
RTS
May 7th, 2011 08:23 PM #1518
- May 2011
- 1
May 7th, 2011 11:40 PM #1519hello everybody, I have a glx strada bought dec2010. After 2 to 3 months maingay na yung leaf spring sa likod. May squeky sound. Yung friend ko din ganun din. Halos magkasabay lang kami bumili. Binalik ko sa kasa. inalign daw at retighten ng bolts. Pero after a few weeks maingay nanaman. Anybody experience this with their strada? Ano ba ang ginawa nyo sa Strada nyo para di pabalik balik yung ingay? Thank you.
May 8th, 2011 12:20 AM #1520
high idle RPM at engine start
