Results 1,461 to 1,470 of 5002
April 30th, 2011 12:43 PM #1462
May 1st, 2011 02:23 PM #1463
Thank you, to Sir ThePatriarch, Sir bluemica, Sir Docglen, Sir Alainroyce for being nice and warm last April 29 mini EB at Cows on Fire Tagaytay with acoustic band pa..hehehehe
- Mar 2009
- 154
May 1st, 2011 02:43 PM #1464gud day
im using 3.2 MT , just like to ask I noticed that when I maintained the RPM at 2k to 2500 I noticed na parang nabubulunan yun engine, hindi pino yun takbo. SCV po ba ang sira nito,
thanks
- Mar 2009
- 154
May 1st, 2011 02:52 PM #1465additional po,
ayaw po mag lock ng alarm ko, so im using the key to lock the car, anu po ba papalitan dun<actuator ba?, last 2 days ko lang napasin ang mga ito, kakapost ko lang na wala pa masydo publema strada ko, but now ang dami na,pati yun stoplight sa left side grounded ata, pag apak ko ng brake nawawala yun ilaw sa left, sa right side lang meron, pag di tinatapakan meron ilaw ang left, heheh sabay sabay.
na experience nyo pi ba ito? anu po remedy?
- Mar 2011
- 20
May 1st, 2011 03:34 PM #1468To Sir av8or5,
I'm doing backthread sa TSCP Strada Mods when I saw your skidplate (1 pc), san po kayo nagpagawa and how much?
thanks in advance..
May 1st, 2011 03:40 PM #1469
Lets separate the dealer installed items from manufacture problem.
The actuator is winterpined installed. Yup meron na problems with that, contact your dealer to have the actuator replaced.
Regarding the tail lights sir, maybe busted double contact bulb. Bili lang kayo bulb.
Two very minor problem that any cars can also experience.
On the rpm between 2000-2500 rpm, if it fluctuates even if constant step on the accelerator pedal, that might be already signs of scv as i experienced that.
May 1st, 2011 03:51 PM #1470
high idle RPM at engine start
